Burning 1qt oil/500 miles... should I be able to see this in the exhaust?
Old Oct 28, 2007 | 06:36 PM
Junkie's Avatar
Default Burning 1qt oil/500 miles... should I be able to see this in the exhaust?
Recently, my car has been consuming about 1qt of oil for every 500 miles of driving. It has a leak, and leaves a spot maybe 1.5-2" in diameter on the ground most nights - but does NOT leak when cold (ie when I pushed it, cold, into the driveway and left it for several hours no oil got on the ground). In front of a friend, I took it up to redline in 1st and then lifted, and he couldn't see any smoke from the exhaust.
So, am I mostly leaking this oil or is that little enough to be burned without being visible?
edit: oh yeah, this is a 1990 Integra GS with the stock B18A1.
Old Oct 28, 2007 | 07:18 PM
ruthless013's Avatar
Default Re: Burning 1qt oil/500 miles... should I be able to see this in the exhaust? (Junkie)
i bought a civic a few years back that had a similar problem, never left much of a stain on the driveway but lost oil like crazy every time i drove it. it was a northeast car with a fair amount of rust underneath - turns out a corner of the oilpan had rusted through the size of a pinhead. invisible to the eye, but when the car built up enough pressure while running, a fine mist would spray from the hole.
maybe get her up on stands/ramps, start her up and look underneath for the obvious?
Old Oct 28, 2007 | 07:27 PM
Junkie's Avatar
Hmm, that's a good idea. I'll have to try that.
It's a CA car and always has been, so no real rust, but it's certainly possible that it has a hole somewhere - it's got plenty of undercarriage damage.
T_ypEr
42
Mar 10, 2012 10:44 AM
rjmq06
Jun 8, 2011 10:15 AM
admsi0608
Engine Management and Tuning
11
Mar 29, 2009 07:23 PM
EF9 JAMS!!!
Oct 7, 2006 12:37 PM
IggDawg
Nov 12, 2003 11:23 AM
