crx fuel pump not priming checked and did all the normal checks
The car is a 90 crx dx all stock. The fuel pump will not prime when you turn the ignition to on. I've done all three relay harness checks in the honda manual and get voltage on all three. All grounds are hooked up and correct. I re grounded the ground wire from the main relay. I've checked the main relay and swapped it five times. I've checked the ign and swap it both are good. I've checked continuity and all wires from the main relay to their locations a nd all are good. Fuel pump primes when you give it power directly, it just that the main relay won't click on, it will when I power it directly from the battery, but not when it's plugged in. I get spark and everything else. Any help please, if not should I wire it directly to the ign?
boosteddohczc
10
Jun 11, 2009 09:57 PM
95turboeg
Jul 7, 2006 11:38 AM
