B16 swap in 1990 Civic EX 4DR HELP!!
Well ive searched all over and have found tid bits on what is needed for a B16 swap in a 1990 Civic EX four door. Does anyone know exactly everything that is needed and what other donor parts can be used? Thanks for all of the help!
https://honda-tech.com/zerothread/1508680
Also the EX is the same basic thing as SI as far as a B-series swaps go. Everything you need is in that link.
Motor, Axles, ECU, Distributor (OBD0 or OBD1), Transmission, Shift Linkage that is what you would need from a donor car.
Additionally you would need B-series motor mounts.
This topic has been covered A LOT so maybe searching in the archives would help you too.
Also the EX is the same basic thing as SI as far as a B-series swaps go. Everything you need is in that link. Motor, Axles, ECU, Distributor (OBD0 or OBD1), Transmission, Shift Linkage that is what you would need from a donor car.
