Help ym B series wont start
Old Oct 28, 2007 | 02:11 PM
lilhatch89's Avatar
Default Help ym B series wont start
This is everything I checked
Fuel Filter
Checked for continuity from injctors to ECU and from injectors to resistor box,
Wired all the wires together at resistor box due to im running obd1 injectors.
If I spray started fluid in the inake car starts and runs awsome until it runs out.
Im getting great fuel pressue.
Fuel pump is working
I checked timing it looks awsome
My setup is obd1 jdm b16a with the obd1 Distributor, obd1 injectors, obd0 wirin harness modded, obd0 pr3 ecu.
Old Oct 28, 2007 | 07:34 PM
Crx Jimmy's Avatar
Default Re: Help ym B series wont start (lilhatch89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilhatch89 &raquo;</TD></TR><TR><TD CLASS="quote">
My setup is obd1 jdm b16a with the obd1 Distributor, obd1 injectors, obd0 wirin harness modded, obd0 pr3 ecu.</TD></TR></TABLE>
you need a odbo dizzy for a obdo ecu
Old Oct 29, 2007 | 02:00 AM
lilhatch89's Avatar
Default Re: Help ym B series wont start (Crx Jimmy)
Car is getting fire, Wiring Harness was converted to run obd1 dizzy
Old Oct 29, 2007 | 03:48 AM
ef yu's Avatar
wouldnt u need a obd1 ecu to run a obd1 dizzy?
Pancho2193
Mar 2, 2013 06:35 AM
Dkahn18
Feb 18, 2009 04:41 PM
Homotor
Feb 16, 2008 08:40 AM
lance_ecl
Apr 8, 2007 11:03 AM
91dxcrx
Jan 22, 2006 09:27 AM
