d16y8 swap into 96 civic hb
Old Oct 28, 2007 | 01:59 PM
sky9's Avatar
Default d16y8 swap into 96 civic hb
hi im gonna be doing a d16y8 swap into my 96 hb pretty soon is there any thing i sould look out for?, i heard that i can use my y7 ecu, would that be a problem?
Old Oct 28, 2007 | 02:32 PM
ifIexplode's Avatar
It should be pretty much straight foward.
I went from a y7 to a y8 and ran the y7 ECU for awhile but it didnt run too well.
Bought a y8 ECU for less than a 100 dollars.
And the only real hard thing with the swap is wiring VTEC from the Solenoid and Vtec pressure switch to the Pinouts on the ECU.
Unless you plan on switchin the whole harness, which i dont think is needed.
Old Oct 28, 2007 | 02:37 PM
Syndacate's Avatar
Default Re: (ifIexplode)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sky9 &raquo;</TD></TR><TR><TD CLASS="quote">hi im gonna be doing a d16y8 swap into my 96 hb pretty soon is there any thing i sould look out for?, i heard that i can use my y7 ecu, would that be a problem?</TD></TR></TABLE>
Don't use your Y7 ECU, the fuel mapping isn't the same, and Y7 won't try to activate VTEC. Use the Y8 ECU, and it's 100% straight drop in except for wiring up VTEC which is nothing more than a few wires.
Old Oct 28, 2007 | 03:46 PM
97Ej6mike's Avatar
Y8 motor uses a 3-wire IACv, and the y8's ecu (P2P) reads for a different evap system, that all 96-00 Dx,LX,CX 's dont have, only the EX. It will throw a CEL and you wont pass inspection UNLESS:
You obtain the charcol canister (has electronic valve on it) and 3-way valve from the honda parts department or a junkyard.
Also... this extra valve is not on the wiring harness, so you will need to wire it in by hand or get a 96-00 EX harness.
Between different placement of the 2nd 02 sensor, a 2 wire IACv, and different plugs for the EVAP system, and VTEC, its much easier to just get a y8 harness, save yourself the trouble.
Old Oct 28, 2007 | 03:55 PM
ifIexplode's Avatar
So what is the actual CEL that it would throw?
cause when i had my y7 ECU on the y8 that was in my car the only CEL i had was 45, too rich/lean and i couldnt figure it out.
Old Oct 28, 2007 | 05:01 PM
sky9's Avatar
is wiring VTEC from the Solenoid and Vtec pressure switch to the Pinouts on the ECU, like doing a mini-me? or can i just run a p2p ecu without wiring up vtec.
Old Oct 28, 2007 | 06:21 PM
97Ej6mike's Avatar
Default Re: d16y8 swap into 96 civic hb (sky9)
Running a p2p ECU with a y7 harness will give you a CEL for the Idle Air control valve, the VTEC components, and EVAP valves. Your getting a CEL with the y7 ecu because the fuel maps between a y7 and y8 are not the same.
Believe it or not, a y8 (direct) swap into any 96-00 that had come with the y7 is allot easier said than done, theres a few OBD related issues that are not only a real pain, but hamper your car's legality for state inspection. I would know, i went thru all the bullcrap for a few months. Hands down, OBD2 is a real pain in the ***. Id recomend you run the y8 with a jumper and a p28.
Old Oct 28, 2007 | 06:37 PM
yoffer's Avatar
Banned
Default Re: d16y8 swap into 96 civic hb (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">Running a p2p ECU with a y7 harness will give you a CEL for the Idle Air control valve, the VTEC components, and EVAP valves. Your getting a CEL with the y7 ecu because the fuel maps between a y7 and y8 are not the same.
Believe it or not, a y8 (direct) swap into any 96-00 that had come with the y7 is allot easier said than done, theres a few OBD related issues that are not only a real pain, but hamper your car's legality for state inspection. I would know, i went thru all the bullcrap for a few months. Hands down, OBD2 is a real pain in the ***. Id recomend you run the y8 with a jumper and a p28. </TD></TR></TABLE>
Would i be able to run my y8 with just a obd2-obd1 jumper harness and a p28 without a chip?But would it be ok to run around on the virgin p28 until it gets chipped and tuned? (geting ready for a tune and i need the p28)
Old Oct 28, 2007 | 06:43 PM
97Ej6mike's Avatar
Default Re: d16y8 swap into 96 civic hb (yoffer)
Virgin p28 should run it fine, it reads for a 1.6l SOHC VTEC motor, abd best part is you have a slightly lower VTEC crossover, and a slightly higher limiter. I hate my p2p, it hits VTEC at 5700, and has a 7200 limiter, where as a p28 is like... ~5200 crossover with a ~7400 limiter.
Differences are that a p28 is OBD1, so it doesnt read for as many parts as a P2P (obd2) would, such as secondary 02, EVAP valves, and a few other small things, i cant remember off the top of my head.
Old Oct 28, 2007 | 06:52 PM
yoffer's Avatar
Banned
Yea, obd2 sucks mega *****. But im getting my p28 harness and ecu from phearable. Are they reputable?
Old Oct 28, 2007 | 06:55 PM
97Ej6mike's Avatar
Default Re: (yoffer)
Yes, ive heard of phearable
Old Oct 29, 2007 | 09:55 AM
sky9's Avatar
ohh ic soo i can get a p28 ecu virgin and obd-1 to obd-2 harness and that would be best to run on the y8 motor rite?
Old Oct 29, 2007 | 10:03 AM
97Ej6mike's Avatar
Default Re: (sky9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sky9 &raquo;</TD></TR><TR><TD CLASS="quote">ohh ic soo i can get a p28 ecu virgin and obd-1 to obd-2 harness and that would be best to run on the y8 motor rite?</TD></TR></TABLE>
That is correct, the P2P ecu would just be a nightmare, been there done that, lol.
Old Oct 29, 2007 | 10:20 AM
sky9's Avatar
alrite thanks a bunch mike
Nickhozel
Feb 16, 2018 08:18 PM
Lasty K
27
Nov 1, 2017 09:03 AM
Toxic3469
Oct 4, 2012 03:44 PM
JDubbs99Civic
May 25, 2005 02:10 AM
