Suspension & Brakes Theory, alignment, spring rates....
adjustable coil overs
Old Oct 28, 2007 | 01:35 PM
Sol Cross's Avatar
Default adjustable coil overs
Ok, not to sound stupid but I am new to the high performance car world. I am going to be running my car in solos next year and eventually in club racing. I am looking at investing in some good adjustable coilovers. What type do people recommend and how easy are they to adjust? Are their tools to make sure that the front and rear setting are correct?
Old Oct 28, 2007 | 02:00 PM
AMR Engineering's Avatar
Default Re: adjustable coil overs (Sol Cross)
I am from Seattle, I am in Kent all the time, do you know any of the BattleJunkies?
Old Oct 28, 2007 | 05:46 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sol Cross &raquo;</TD></TR><TR><TD CLASS="quote">Ok, not to sound stupid but I am new to the high performance car world. I am going to be running my car in solos next year and eventually in club racing. I am looking at investing in some good adjustable coilovers. What type do people recommend and how easy are they to adjust? Are their tools to make sure that the front and rear setting are correct? </TD></TR></TABLE>
Solo I (time trials) or Solo II (autocross)?
Budget?
Vehicle?
Class?
Other preparation?
Old Oct 30, 2007 | 10:38 AM
Sol Cross's Avatar
Default Re: adjustable coil overs (Targa250R)
No, I don't know anyone doing solos yet. We went to the last race, but didn't stay long.
I am driving a 1997 del Sol S. It will be for Solo II, STS2 class. Currently we are working on adding new rotors and pads, but will also be adding sway bars, new wheel and tires and several other items. It also has strut bars already. I was considering the adjustable coil overs so we can lower it at the track and raise it up to drive it home.
Old Oct 30, 2007 | 02:23 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sol Cross &raquo;</TD></TR><TR><TD CLASS="quote">No, I don't know anyone doing solos yet. We went to the last race, but didn't stay long.
I am driving a 1997 del Sol S. It will be for Solo II, STS2 class. Currently we are working on adding new rotors and pads, but will also be adding sway bars, new wheel and tires and several other items. It also has strut bars already. I was considering the adjustable coil overs so we can lower it at the track and raise it up to drive it home.</TD></TR></TABLE>
Without an alignment machine, you can't lower it at the track. Your toe will be all kinds of messed up.
Adjustable height spring perches are to set at a given height, align the car, and leave alone.
For a STS2 Del Sol, a set of Koni Yellows and Ground Controls should probably be the entry level suspension choice. Custom rates, as stiff as you think you can drive the car with on the street (unless it will be towed to events). Not sure on the smaller wheelbase of the Sol, but following similar rates to hatchback owners would probably be a reasonable starting point. Somewhere in the 400-600 range on both ends, probably with the rear slightly stiffer, depending on ARBs used.
Old Oct 30, 2007 | 11:36 PM
joebangaa's Avatar
Default Re: adjustable coil overs (AMR Engineering)
BC Racing? Function Form? PIC? KSport??
Old Oct 31, 2007 | 07:23 PM
Sol Cross's Avatar
Default Re: adjustable coil overs (joebangaa)
Thanks! I thought with an adjustable camber kit and a camber measuring tool you could lower them at the track and adjust it. Is there something else involved as well?
Old Nov 3, 2007 | 12:34 AM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joebangaa &raquo;</TD></TR><TR><TD CLASS="quote">BC Racing? Function Form? PIC? KSport?? </TD></TR></TABLE>
dude you didnt just really suggest ksport to a guy who's trying to put his car on a track did you?
if you have the money i suggest TEIN monoflex, if you cant afford that then koni/GC set up should be great too.
dc2teg06
Suspension & Brakes
15
Jul 4, 2009 04:31 PM
turbodsm15
14
Feb 23, 2009 10:08 PM
mkinpwrat12g's
Suspension & Brakes
Apr 4, 2006 09:06 PM
Freeltec
15
Feb 8, 2006 10:13 AM
oscar_lopez03
Jun 25, 2004 06:36 PM
