Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
Oil in Radiator
Old Oct 28, 2007 | 01:26 PM
qnealstevens1104's Avatar
Default Oil in Radiator
Hi Folks,
I'm a newbee here, So, bear with me for a minute.
I've got a 98 RL and it's got oil in the radiator. There's no antifreeze in the engine oil or the trans. I think it’s the engine oil seeping into the coolant system because the oil level has dropped about 1/4 of a quart. The last thing I did was replace the oil with synthetic oil. That was a week ago.
I've seen water in the engine block and even water in a trans before, when the trans cooler line cracked in the radiator. But I've never seen this one before.
Oh, the cars not missing, it's running fine. Well, except for the oil in the radiator.
Any thoughts,
Thanks in advance
Old Oct 28, 2007 | 09:21 PM
dtapia's Avatar
Default Re: Oil in Radiator (qnealstevens1104)
i would check for a blown head gasket although acura's dont normally mix oil and coolant unless the head is cracked. if you have has access to a smog machine you can have them check to see if their is any h/c in the cooling system.
Old Nov 7, 2007 | 02:55 PM
kroze's Avatar
Default Re: Oil in Radiator (dtapia)
Blown head gasket. I know. I had a MKIII supra
Old Nov 11, 2007 | 06:22 AM
YeuEmMaiMai's Avatar
oil in rad......blown head gasket time for a rebuild
cristegra09
May 14, 2009 11:45 AM
y2kferari
May 3, 2009 11:05 PM
Aodhan
20
Oct 24, 2007 01:58 PM
inland180
Mar 27, 2007 10:56 AM
92hybridAccord
Nov 26, 2003 04:05 AM
