Too Much Oil?
Not sure which manual ur reading but the helms says 3.7L (3.9qts) if it's a complete engine overhaul, and 3.3L (3.5qts) for an oil change.
Are you filling it up for the first time or are you changing the oil?
1 L <> 1 qt.
With that said, it's supposed to take 3.5qts on an oil change, you put in 4 quarts, yeah, that's fine, your oil won't foam at that level.
1 L <> 1 qt.
Yeah sorry, I was just doing an oil change. Good to hear that 4 quarts is not too much.
I checked the dipstick and it is a like 1/8 of an inch higher than the high level on the stick.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK_B »</TD></TR><TR><TD CLASS="quote">Yeah sorry, I was just doing an oil change. Good to hear that 4 quarts is not too much.
I checked the dipstick and it is a like 1/8 of an inch higher than the high level on the stick. </TD></TR></TABLE>
Yeah, that's 100% fine.
kegard
32
May 30, 2005 12:12 AM
