clutch bleeding?
Old Oct 28, 2007 | 12:20 PM
VtecVillan's Avatar
Default clutch bleeding?
I just did my motor swap/tranny swap, brand new clutch/flywheel and I have loose pedal play. We bled the clutch once. At one point the pedal play was stiff, then went soft. Do I keep bleeding the clutch until the pedal becomes stiff again?
Old Oct 28, 2007 | 12:27 PM
philosofy1's Avatar
Default Re: clutch bleeding? (VtecVillan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecVillan &raquo;</TD></TR><TR><TD CLASS="quote">I just did my motor swap/tranny swap, brand new clutch/flywheel and I have loose pedal play. We bled the clutch once. At one point the pedal play was stiff, then went soft. Do I keep bleeding the clutch until the pedal becomes stiff again? </TD></TR></TABLE>
yes, you need to continue to bleed. make sure all lines are nice and tight, not too tight, but tight enough where air isn't entering the lines. also, make sure the clutch resevoir never runs dry, and you have the cap on while bleeding. if it runs dry air just enters the line again and you need to start over.
it is easier if someone is helping you.
Old Oct 28, 2007 | 12:56 PM
Bond's Avatar
Default Re: clutch bleeding? (philosofy1)
i would just suggest to vacuum bleed it if u can. if not ur going to need 2 people for this job. the setup on honda's hydrolic clutch designs is not the greatest for bleeding. just keep at it till no more air comes out.
faridos
Sep 21, 2007 04:04 PM
93SiHB
Oct 2, 2005 10:00 AM
Y2ksi
Apr 7, 2005 07:55 PM
Simple
Sep 17, 2004 11:16 PM
AKUFC
Sep 13, 2003 04:02 PM
