recommendations for my civic
im getting my exedy clutch in tommorow. what else should i do while i got the tranny out?? im doing clutch pressure plate throw out bearing, should i change the fluid while it is out??? if so what kind of fluid is the best? i was thinking about shaving some weight off of the flywheel good diea?? i no it will make my idle a little rough but thats fine. thx h-t
what motor are you running? what kind of exedy clutch are you throwing in? OE? stage 1? how many miles is on the tranny? i would get a new slave cylinder, when i did my tranny swap my old slave went out on me, its cheap and will save you time in the long run. Yes change the fluids, either use GM mesh, honda MTF, or reg. motor oil. There's alot of debate on this topic so you decide.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxricer66 »</TD></TR><TR><TD CLASS="quote">nobody knows where the slave cylinder is??</TD></TR></TABLE>
Front of the transmission between the bell housing and the radiator fan.
neverstop
Transmission & Drivetrain
Feb 18, 2010 11:40 AM
