CLUTCH HELP
Old Oct 28, 2007 | 10:24 AM
redlsvtec4door's Avatar
Default CLUTCH HELP
im doing a clutch job on a 95 civic dx . the clutch is a exedy clutch
the problem is that the transmission is not going into gear. i replace the clutch master cyclinder and slave cyclinder. and still nothing.
i tore the tranny back out to see if the i installed the clutch disc properly and if everything is matches up to the old clutch set-up.
now the new problem is that i cant get the tranny lined up to the engine again. i have a adjusted/ aligned the clutch 10+ times trying to get the imput shaft to line up but it wont.
can anyone HELP and give me some ideas. thanks in advance
Old Oct 28, 2007 | 11:03 AM
black0hatch's Avatar
Default Re: CLUTCH HELP (redlsvtec4door)
ya it can be a bitch to put back on sometimes you just gota line it up right. try greasing the shaft. or turning it a little. for the other problem did you bleed the clutch when you changed all that stuff. and did you adjust the clutch master cylinder? thats probably your problem.
OUTKAST1779
Jul 18, 2009 11:19 PM
sheBangZ
Oct 16, 2007 05:04 PM
bpetruzzo
Nov 30, 2005 03:44 AM
iLOVEmyEMone
Oct 28, 2005 05:31 PM
hondaracing1
Jun 22, 2005 11:15 AM
