Finally Spoon Equipped - First Drive Review and Pictures
Old Jun 21, 2002 | 07:56 PM
itrsport.com's Avatar
Default Finally Spoon Equipped - First Drive Review and Pictures
Keep your hands inside at all times - the Spoon roller coaster has just begun...
In one word - Amazing! I noticed a difference in how the car drives even before I left the Acura parking lot. No joke! The Spoon calipers are so much lighter than the stock calipers that considerably less effort is needed to turn the steering wheel. This sure caught me by surprise. It feels like the power steering is on overdrive. The spoon calipers weigh about 5.5 pounds each while the stock calipers are approximately 13.5 pounds each.
Brake feel and control is quite a bit different from stock. The new braking pedal range is about two times longer than the stock setup. This allows you to have more control during aggressive breaking or during normal driving situations. In addition, the actuation of the brakes is now more linear than the abrupt and almost immediate bite of the stock system. This is the primary characteristic that makes them a killer tool out on the track. Even with the improved braking force that the Spoon calipers provide, the driver can avoid locking up the wheels while driving at the limit.
The pedal feel is fantastic. I did a few aggressive braking passes from 80 to 50 mph (probably only about 75% max) and the car’s speed dropped like a rock. You can feel how the four piston design displaces the braking force on the caliper more evenly from the brake pad, again, allowing for more control and less drama.
Here are a couple pictures of the virgin Spoon calipers and Brembo rotors. It's time to hit the road again.
Wallpaper
http://24.161.125.125/02_jun_spoon_o...spoon_on_3.jpg
[Modified by itrsport.com, 9:02 PM 6/21/2002]
Old Jun 21, 2002 | 07:59 PM
Tommy_Gunns's Avatar
Default Re: Finally Spoon Equipped - First Drive Review and Pictures (itrsport.com)
I always wondered...does ABS still work?
Old Jun 21, 2002 | 08:00 PM
Default Re: Finally Spoon Equipped - First Drive Review and Pictures (Tommy_Gunns)
Yes
Old Jun 21, 2002 | 08:04 PM
StinkyTofu's Avatar
Wow, looks nice. I have a question. Since acura installed them, are you still under warranty?
Old Jun 21, 2002 | 08:05 PM
hybrider's Avatar
Old Jun 21, 2002 | 08:10 PM
Default Re: Finally Spoon Equipped - First Drive Review and Pictures (StinkyTofu)
I have 47,000 miles on my car so the warranty is over.
But installing aftermarket products will not terminate your warranty. However, If a vehicle has a warranty and the aftermarket brakes fail and it's not caused by a problem due to installation Acura would not be liable. The rest of the car will still be under warranty.
Old Jun 21, 2002 | 08:11 PM
Dodger2940's Avatar
Default Re: Finally Spoon Equipped - First Drive Review and Pictures (hybrider93)
I know this is a stupid question, but do you only get 2 calipers?
xanctus's Avatar
sweeeeeeeeeeet Josh...
well as I said, have fun with your new toy hhehehehe
Old Jun 21, 2002 | 08:28 PM
electronspeeder's Avatar
Default Re: Finally Spoon Equipped - First Drive Review and Pictures (xanctus)
What kind of pads are you running? I'm sure they make a larger difference in pedal feel, initial bite than calipers themselves.
[Modified by electronspeeder, 12:28 AM 6/22/2002]
Old Jun 21, 2002 | 08:41 PM
Default Re: Finally Spoon Equipped - First Drive Review and Pictures (electronspeeder)
I'm running new stock pads and the original brake lines for the first couple months.
Old Jun 21, 2002 | 08:43 PM
frogsr's Avatar
very nice.
Old Jun 21, 2002 | 09:06 PM
Tweakmeister's Avatar
Default Re: Finally Spoon Equipped - First Drive Review and Pictures (frogsr)
*drool*
Old Jun 21, 2002 | 09:39 PM
itr0032's Avatar
Default Re: Finally Spoon Equipped - First Drive Review and Pictures (Tweakmeister)
Old Jun 21, 2002 | 10:20 PM
underrated99si's Avatar
Default Re: Finally Spoon Equipped - First Drive Review and Pictures (itr0032)
I always wondered of the VOLKS TE37's would clear the the spoon calipers I wonder if 15,16's would clear as well?
Old Jun 21, 2002 | 11:01 PM
Kengs's Avatar
Default Re: Finally Spoon Equipped - First Drive Review and Pictures (underrated99si)
Very nice; insightful info too
Old Jun 21, 2002 | 11:05 PM
Stumpy's Avatar
Default Re: Finally Spoon Equipped - First Drive Review and Pictures (kengs)
Very Nice!
Old Jun 21, 2002 | 11:08 PM
AllMotorITR's Avatar
New User
Default Re: Finally Spoon Equipped - First Drive Review and Pictures (Stumpy)
Damn!! the Spoon calipers compliment your rims nicely.. I love it! Your R definitely gets
Old Jun 21, 2002 | 11:27 PM
MyYellowHonda's Avatar
New User
I want some but i really can't afford it..
If i could though, them Spoonies definately what i'd pick
Old Jun 22, 2002 | 12:20 AM
jet's Avatar
jet
New User
Default Re: Finally Spoon Equipped - First Drive Review and Pictures (MyYellowHonda)
all i can say is wow.....spoon should hire you to market their stuff cause after reading your review, i can see my piggybank losing weight sometime soon pics are fantastic...
Old Jun 22, 2002 | 12:30 AM
GokuSSJ4's Avatar
Default Re: Finally Spoon Equipped - First Drive Review and Pictures (jet)
Old Jun 22, 2002 | 01:08 AM
MTK Kommander's Avatar
those are 16's on his car.. look at his tire "205 / 45/ ZR 16."
Old Jun 22, 2002 | 04:16 AM
CPR's Avatar
CPR
I'm no mechanic but I remember that when I first bought my car, I was advised to take it easy on the brakes for a couple hundred miles. Wouldn't this advice apply to you since you just installed new brake components? Just a thought...
Old Jun 22, 2002 | 05:28 AM
Super7's Avatar
Why? Warranty is 4year/50000.
Old Jun 22, 2002 | 05:53 AM
importtuner's Avatar
Default Re: Finally Spoon Equipped - First Drive Review and Pictures (CPR)
That's true, but that's only valid if the brake pads are new. Since Josh is using stock pads, there is no need to break them in. Kinda off topic, but are there any brake upgrades for the rear brakes??
-importtuner
Old Jun 22, 2002 | 06:03 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
wow, i didn't know you can use stock pads! i thought the spoon caliper required a different pad. cool, i gotta get me a set now....
