no oil in motor, car shutted off
Old Oct 28, 2007 | 09:07 AM
Luward's Avatar
Default no oil in motor, car shutted off
so my friend was driving home last night and he didnt noticed that he busted his oil pan so oil was leaking out everywhere. while driving home on the highway, the car shutted off. we are gonna try to replace the pan today, but was wondering what would happened to the bottom end if there was no oil in it.
Old Oct 28, 2007 | 09:08 AM
b20acura's Avatar
Default Re: no oil in motor, car shutted off (Luward)
no oil youll seize your motor.
goheel's Avatar
just hope the motor didn't seize.
Old Oct 28, 2007 | 09:09 AM
St Jimmy's Avatar
* B A N N E D *
The motor probably seized up and replacing the oil pan probably wont do anything, but its worth a try.
Old Oct 28, 2007 | 09:11 AM
Junkie's Avatar
Let me think about what's gonna have been destroyed by having NO oil...
likely all the bearings, as well as damage to the crank
all the pistons/rings/walls... it'll need a fresh overbore
cams maybe? dunno really
anyway, it isn't really worth rebuilding.
Old Oct 28, 2007 | 09:18 AM
Luward's Avatar
he told me that the motor still cranks...so i dont know..its a k20 in a dc2, so lets hope everything is ok...
Old Oct 28, 2007 | 09:22 AM
St Jimmy's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luward &raquo;</TD></TR><TR><TD CLASS="quote">he told me that the motor still cranks...so i dont know..its a k20 in a dc2, so lets hope everything is ok...</TD></TR></TABLE>
Wow thats almost as bad as the guy that sucked a penny into his intake. Why would you try to start a car with no oil?????
Old Oct 28, 2007 | 09:35 AM
b20acura's Avatar
Default Re: no oil in motor, car shutted off (St Jimmy)
wow k20. he really shouldnt be touching it if he doesnt know what he's doing. pretty expensive motor.
Old Oct 28, 2007 | 10:01 AM
Tizight's Avatar
Wow, a K20 DC2. That really sucks.
Did he never look at his temp gauge? Hell, I take a glance at my temp gauge like every couple minutes.
Old Oct 28, 2007 | 10:11 AM
St Jimmy's Avatar
* B A N N E D *
Default Re: (Tizight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tizight &raquo;</TD></TR><TR><TD CLASS="quote">Wow, a K20 DC2. That really sucks.
Did he never look at his temp gauge? Hell, I take a glance at my temp gauge like every couple minutes. </TD></TR></TABLE>
... or the oil light
Old Oct 28, 2007 | 10:24 AM
Tizight's Avatar
Default Re: (St Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by St Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">
... or the oil light</TD></TR></TABLE>
I knew I forgot something
Old Oct 28, 2007 | 12:02 PM
azVTECaccord's Avatar
wow... just wow...
Old Oct 28, 2007 | 10:10 PM
Luward's Avatar
he was just driving home at night and the oil light didnt even turn on at all. it just shutted off and he was wondering what happend and try to crank over the motor, but wouldnt start, so he stepped outside the car and saw the trail of oil.
Old Oct 28, 2007 | 11:52 PM
gsrob's Avatar
Default Re: (Luward)
So his car shut off and that's when he realized something was wrong? He didn't stop to see what was damaged after he hit whatever with the oil pan? They usually don't just fall apart, especially on a brand new motor. I think we are all missing something here.
Old Oct 29, 2007 | 12:12 AM
typeR#0427's Avatar
Default Re: (azVTECaccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azVTECaccord &raquo;</TD></TR><TR><TD CLASS="quote">wow... just wow...</TD></TR></TABLE>
im speechless right now. what the hell were you thinking?? seems like a person with that new of a swap would have a clue. guess not.
good luck rebuilding it.
Old Oct 29, 2007 | 05:06 AM
AWD Terror's Avatar
Default Re: (typeR#0427)
A car will run for a few mins without any oil/pressure.
When it gets to the point when the car shuts off, you are screwed. If he shut it off himself, there is a chance that it will be ok
Old Oct 29, 2007 | 06:11 AM
dizzzane's Avatar
Default Re: (AWD Terror)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AWD Terror &raquo;</TD></TR><TR><TD CLASS="quote">A car will run for a few mins without any oil/pressure.
When it gets to the point when the car shuts off, you are screwed. If he shut it off himself, there is a chance that it will be ok</TD></TR></TABLE>
Solid answer.
And stop saying shutted please. One would either say turned or shut but not a combination of the two.
Old Oct 29, 2007 | 06:46 AM
slo_hatch's Avatar
running your car with no oil will cause friction between all of your moving parts inside your block and head. so yeah it will wear it out and eventually seize....but this could take a while or it could happen first time your out....but it sounds like that bitch seized if it shut off like that....thats how one of my cars motor locked up. but my hatch was out for like 3 days with no oil...so just dont drive it and replace your oil pan and keep oil in there if it still runs!! lol but that sounds like a nice build...hope everythings ok.
Old Oct 29, 2007 | 07:35 AM
AWD Terror's Avatar
First thing I would do is change the oil pan.
Then dump about 40% Lucas oil stabilizer in just to help out.
Start cranking and praying.
I've ran two vehicles out of oil based on pure stupidity. They were both 70's ford trucks. The 300 inline six ran for about 3 mins without oil. Every start up after was some loud tapping, but it went away as the truck warmed up.
guy_from_nerk
Aug 2, 2010 09:39 PM
quazar
27
Oct 29, 2004 12:49 AM
Unknown Member
Mar 8, 2003 02:55 PM
