OBD1 B16 and GSR harness the same?
I have a JDM OBD1 B16 swap that needs a harness. I have someone telling me a ODB1 GSR harness will work, all plug and play. It this correct? Are the harness's the same?
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by islandauto »</TD></TR><TR><TD CLASS="quote">The harness will work but u might get a check engine light for sensors not plugged in</TD></TR></TABLE>Wrong...if he is just using the harness not a GSR ecu, it WILL NOT throw a code because there is no sensor to detect.
dont listen to this guy. it will work fine you will have some extra plugs and it wont throw a code because your ecu wont be looking for it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NVturbo »</TD></TR><TR><TD CLASS="quote">Yes, the harness will work. You will have some plugs that will not be used. (knock sensor, secondary butterlies)</TD></TR></TABLE>
yea p30 has a knock sensor,.
what would i need to do to use an obd0 harness with an obd1 ecu? would the conversion harness plug in or do i need to solder some wires?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aleks708 »</TD></TR><TR><TD CLASS="quote">what would i need to do to use an obd0 harness with an obd1 ecu? would the conversion harness plug in or do i need to solder some wires?
</TD></TR></TABLE>You can purchase a conversion harness for around $75 or so. For that much money, you can actually find one WAY cheaper from Pull-A-Part Salvage, even if it is a Non-VTEC harness.
jdmekrobot
Mar 13, 2008 12:13 AM
Usdmowns
Nov 30, 2007 04:01 PM
