Prelude 1997 (4 wheel steer)
Old Oct 28, 2007 | 07:03 AM
Wayne Hawkins's Avatar
Default Prelude 1997 (4 wheel steer)
I have an issue with my 4 wheel steer light - can some one be so kind to advise me how to clear the error, or point me in the right direction on where to get the guidance from - The dealer want to charge £50.00 to clear a light !.
My Mrs hit a kerb when parking.
Old Oct 28, 2007 | 08:50 AM
roflcopterdown's Avatar
Default Re: Prelude 1997 (Wayne Hawkins)
Its probably a wheel sensor if all she did was hit a curb. is anything noticeably bent up?
Old Oct 28, 2007 | 08:59 AM
Default Re: Prelude 1997 (roflcopterdown)
Hi
No nothing is bent I just need to reset the system however the guide I have doesn’t reset the error code.
I have tried to reset with a jumper and also removing the 10amp fuse however it’s not sorted it... and £50.00 $100.00 is made.....
Any help would be appreciated...
Old Oct 28, 2007 | 10:04 AM
Default Re: Prelude 1997 (hamadiscool)
Hi
I will give it a go tommorow many thanks for your time ...
Old Oct 28, 2007 | 03:16 PM
mattsnooz's Avatar
Also, if you pull your cel 2 pin connector out from around behind your center counsil (blue 2 pin quick connector), than jump the connector using a paper clip (pretty much put one end in one side and other end in other side to jump the connection) and watch your 4WS light blink. Long pulses equal incriments of 10 and short pulses indicate 1's. So ie. if you get a long followed by 2 short ones together without any long gaps between pulses, than its 12, (10+2). If they are separated by a long duration than it could be two separate codes.
That number will give you whats wrong with your 4 ws system.
Some codes might just keep coming back though even after you clear them, If something is still wrong. If something is broken you should find out what you broke than just try and have it fixed or fix it yourself.
Old Oct 29, 2007 | 09:06 AM
Default Re: Prelude 1997 (mattsnooz)
Can you tell me how to reset the 4 wheel sterr now I have the codes please
Old Oct 29, 2007 | 09:53 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wayne Hawkins &raquo;</TD></TR><TR><TD CLASS="quote">Can you tell me how to reset the 4 wheel sterr now I have the codes please
It's already been said, dosconnect the battery for 30 seconds.
Old Oct 29, 2007 | 11:12 AM
Default Re: Prelude 1997 (Hawkze_2.3)
Hi
I have disconnected the battery and the 4 wheel steer light stays on and the 4 wheel steering still does not work any thoughts would be appreciated the code was a 23 which is KS (Knock Sensor) defective circuit or unplugged / defective sensor.
Sorry if I sound a little dump but I have followed the advice given and also searched the net for many solutions including the 4 wheel steer service manual but I still unable to reset the system..
Many thanks.... for your time replying
Old Oct 29, 2007 | 11:34 AM
95 integra's Avatar
You're not going to be able to clear the light until you fix whats causing the light....which is apparently a busted sensor.
Old Oct 29, 2007 | 01:05 PM
AndyD's Avatar
If your car is like my 4th gen, pull the radio fuse and it will reset your 4WS ECU. If not, as said before, pull the negative bayyert cable.
It could be that the alignment is off now too.
As soon as you start the car, does the light come on or does it come one when you drive for a little bit?
Old Oct 30, 2007 | 03:27 AM
gavzter's Avatar
i dont think that the 4ws ECU uses any input from the knock sensor to function - I think youre reading the wrong codes. Plus the fact that the UK VTi's don't have a knock sensor!
The codes may be different from the 4th gen 4ws codes too. Unfortunately only UK and Jap 5th gens had 4ws available, so most people here won't be any specific help for your car.
You could try PreludeUK - not sure if there's any specific links to the 5th gen 4ws in the tech section there..
Gavz
Modified by gavzter at 4:40 AM 10/30/2007
Old Oct 30, 2007 | 08:23 AM
Default Re: Prelude 1997 (gavzter)
Hi
Thanks to all who offered their help I've been io the dealer and they are going to look at it next week. So thanks to all who posted cheers...
Many thanks
Closed thread
Modified by Wayne Hawkins at 9:38 AM 10/30/2007
turdbomb
Aug 28, 2016 04:48 PM
2ndlife
Dec 5, 2006 09:58 AM
99PreludeSh
Jun 8, 2006 11:39 AM
2.2 teg
Jan 2, 2006 07:12 AM
Chiller
Jul 10, 2003 09:27 PM
