Nasty Puddle and Car Won't Start
Old Oct 28, 2007 | 05:11 AM
slacks's Avatar
Default Nasty Puddle and Car Won't Start
I hit a nasty puddle two nights ago driving someone home. The car drove home fine but didn't start the next morning when I needed to get to work.
As of last night my family helped push-start the car and it ran fine so it's looking like the starter.
Although the starter is recently new
All fuses are good as well as grounds. Any suggestions to help this out?
Old Oct 28, 2007 | 07:15 AM
darkclark's Avatar
Default Re: Nasty Puddle and Car Won't Start (slacks)
pull out all the spark plugs and turn it over to be certain it did not hydrolock even thought that does not sound like your problem
Old Oct 28, 2007 | 08:54 AM
civicbackwords's Avatar
Default Re: Nasty Puddle and Car Won't Start (darkclark)
had the same problem
took a couple things off and put them back on
and the car started
Old Oct 28, 2007 | 09:01 AM
slacks's Avatar
Default Re: Nasty Puddle and Car Won't Start (civicbackwords)
it's not the spark plugs because i did have the car running with the push start
the problem is that it is not cranking or clicking
Old Oct 28, 2007 | 09:05 AM
devney's Avatar
well if you can push it and it starts, I'm going to guess that it's your starter
Old Oct 28, 2007 | 09:08 AM
devney's Avatar
by the way, there is a little black wire that goes to your starter, check and see if that is still connected because it can come off
Old Oct 28, 2007 | 09:33 AM
slacks's Avatar
Default Re: (devney)
i'll check both of the wires and see if they fell loose.. they were on yesterday but maybe not totally on
Old Oct 28, 2007 | 11:48 AM
slacks's Avatar
fixed it.
wasn't anything wrong
the car was a mechanical tranny swap and not electrical... so the "shifter" wasn't in park all the way hahaha
mattbeezy
Apr 30, 2010 06:41 PM
bg-33p
Nov 23, 2007 09:43 PM
HybridGSR1
Jul 13, 2004 02:16 AM
tmekjian
Jul 28, 2003 10:06 AM
