finally finished my jdm b18b swap in a eg
Old Oct 27, 2007 | 07:32 PM
egjdmcivichatch's Avatar
Default finally finished my jdm b18b swap in a eg
geez its been the longest 4 months for me.
so happy with it, pulls like crazy its really torquey.
setup
jdm b18b obd1, 95 cx hatch, fuel rail, rc 270cc saturated, chipped pr4 ecu also tuned for the 270's,ctr crank pulley, 95 cx cai aem (bolted up perfect), stock pr4 intake manny, dc ceramic 4-2-1, full exhaust straight back, ngk blues, ngk iridium 9's, with a stock gsr tranny, so much mor to buy but im glad shes runnin no cels all clean
revs really quick with good torque,
Old Oct 27, 2007 | 08:36 PM
97Ej6mike's Avatar
Thanks for the update chief
LOL i had to.
Old Oct 27, 2007 | 08:44 PM
Default Re: finally finished my jdm b18b swap in a eg (egjdmcivichatch)
anytime
Old Oct 27, 2007 | 11:53 PM
yoffer's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egjdmcivichatch &raquo;</TD></TR><TR><TD CLASS="quote">anytime</TD></TR></TABLE>
i hate that picture.
Old Oct 28, 2007 | 04:26 AM
instrument's Avatar
this better?
Old Oct 28, 2007 | 04:51 AM
daluv's Avatar
What kind of times are you running with it?
Old Oct 28, 2007 | 06:47 AM
Default Re: finally finished my jdm b18b swap in a eg (daluv)
no times yet just barely got done with it yesterday, ran a integra gsr and won twice by a fender
gsr full interior
noraml bolt ons
eg--&gt; gutted just two seats
Old Oct 28, 2007 | 06:55 AM
EJ6_ROY's Avatar
congrats man. glad to hear it's going well for you. hopefully my swap goes well.
Old Oct 28, 2007 | 10:02 AM
Default Re: finally finished my jdm b18b swap in a eg (EJ6_ROY)
EJ6
what swap are u doin?
for some tech on a b18b in a cx( what i learned)
exhaust collector had to be twisted to fit the header,
ls throttle cable
had to use a t bracket off a b16 ls one was to long
1 wire &lt;-- cx vs the 4 wire, did want to deal with it just got th ecu re programed to not check for the o2, the car doesnt throw any codes.
everything else was chill except getting the belt on the ctr pulley.
Old Oct 28, 2007 | 01:59 PM
daluv's Avatar
Nice. Once you start learning the motor and getting used to it, you should be a good full car length ahead of those GSR's. I had the same setup in a 93 coupe and was running 14.9 with it, with a full interrior with only an intake and catback exhaust. Im putting the setup into my new hatch now in hopes to see some mid 14's. Good luck man, hope all works out for you! The LS t bracket was too long for you??? Thats what I used in my setup, worked fine. What mounts are you using?
Old Oct 28, 2007 | 03:23 PM
yes indeed just breakin her in gettin the feel for the motor,
yeah that damn t bracket didnt fit i doubt the jdm one is different from the u.s but o well, im using the hasport mounts dcstk.
sweet that u had the same setup i really like the b18b its a good strong motor, with the ctr pulley im going through gears like its nothin 1 to 4th quick its sweet
good luck with the swap let me know on the up dates
i see ur runnin b20 if im not mistaken, which one pulled hard ur stock b20 or the b18b? its seems back n fourth on which one pulls harder.
Old Oct 28, 2007 | 03:41 PM
Gtimportfanatic's Avatar
im looking on doinga B16 in my EG sedan soon.. how hard was this swap?
Old Oct 28, 2007 | 03:50 PM
Default Re: (Gtimportfanatic)
thats sweet obd0 or sir 11?
it wasnt all that hard it was my first swap also my first jdm motor, i had that crapy *** 70hp motor.
some problems i ran into was after the d series was out i tried dropping it in with the ls t bracket and didnt fit was too long i was like wtf so i had to wait to get a b16 one. once the motor was in pretty much plug n play, used a 95 ls harness so it made it go easier and the ctr pulley was a *** but once on there it was chill
it took me 2 full days, i say it was in between not easy not hard. u shouldnt have any problems with ur swap, if u got the right harness mounts ect.. it should be fairly keep me updated also
Old Oct 29, 2007 | 10:38 AM
EJ6_ROY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egjdmcivichatch &raquo;</TD></TR><TR><TD CLASS="quote">EJ6
ls throttle cable
everything else was chill except getting the belt on the ctr pulley.</TD></TR></TABLE>
I'm throwin a B16A2 in my 97 DX. I know what i need as far as mounting parts, charging system, etc, but the wiring is one that i'll be reading up HEAVILY on. I think I remember a thread somewhere on H-T about this exact swap.
Old Oct 29, 2007 | 04:33 PM
daluv's Avatar
You can definatley feel that little bit of extra torque from the B20, but she does lack in the top end. B18B, lacking in the lower RPM's, but very nice in the mid-uppers. I was able to pull a best of 14.5 with the B18B+GSR Tranny in the batch, which is right where I was expecting to be. I think I might do a little tinkering with both motors. I might try putting the LS head on the B20B Bottom to see if I can get a good happy/medium between the both. Each motor makes up for what the other lacks. I figure that since the B20 is good for bottom end power, and the B18 is good for top end, if I put them together, it should make a pretty nice setup. Just gotta research the differences in deck height, piston sizes, rod lengths, etc.
Old Oct 29, 2007 | 06:59 PM
yeah i hear the b18b head on the b20 is ill cause of the head flow. good luck with that.
later on down the road when i go ls-v im thinking about putting a b16b head on it if i can find one, dont know all the things i have to do to make it work yet but ill know when the time comes.
also it would be different cause i havent really seen b16b heads on anything besides the full swap.
Horseofcourse
Jun 18, 2007 11:45 PM
rEnZ94tEgGy
Apr 29, 2007 10:11 PM
Sleek98
Feb 16, 2005 07:41 PM
JDM EJ1 95
Sep 27, 2004 05:13 PM
eddie1681
Apr 4, 2002 09:59 AM
