LMA3 rpm signal problems
Old Oct 27, 2007 | 04:30 PM
pane93civhb's Avatar
Default LMA3 rpm signal problems
I'm trying to wire an LMA3 into a 2000 integra gsr with an obd2->obd1 conversion harness and chipped p28. Innovate's website says to take the rpm signal from pin A21 which is the ignition control module. On my conversion harness A21 goes to the ignition control module and the tach on my stock harness. With a volt meter it reads about 11.7 volts at idle and goes down with rpm (tried several ground spots and different grounds from the ecu). The LMA3 reads it s 1.6 at idle and goes up...but the LMA3 can't read sensors that go above 5 volts so I think something must be wrong. Does anybody have any ideas or know what I might be doing wrong? Thanks in advance for any help.
Old Oct 27, 2007 | 05:53 PM
averyvm's Avatar
Default Re: LMA3 rpm signal problems (pane93civhb)
wish I could help but i cant
Another_Si_Guy
19
Feb 25, 2016 01:45 PM
_inline4turbo_
Mar 4, 2011 04:54 PM
one-cam
Aug 31, 2008 05:27 PM
Sonnick
Aug 19, 2007 08:37 AM
c rex 88
Mar 22, 2006 07:46 PM
