Adding Tach to Factory Cluster
My 96’ Civic does not have a tach and I was originally going to get a new cluster off eBay. However, my only problem is I want to keep a.) my original mileage b.) my km/hr speedo.
Is it possible to take my current cluster and switch the outer gauges? I.E leave the km/hr speedo and odometer in the center and add the tach gauge on the left and the fuel/engine temp combo on the right)
No, but you can do it the other way. Leave the tach, temp, and fuel gauges in. Then swap in your speedo/odo in that cluster. Only 4 screws in the rear.
just buy an EX cluster (one with a tach) and just put your speedo in it. that way you have your mileage and your km/h and you ahve a tach.
atleast i think that should work. somone please confirm this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BridgeSVT »</TD></TR><TR><TD CLASS="quote">And then everything will be plug and play? The tach will work with nothing else?
Thanks for the replies</TD></TR></TABLE>
Yup & yup
Yup & yup
new_climber
May 13, 2013 12:25 PM
