Swap start up problems
Old Oct 27, 2007 | 12:11 PM
VtecVillan's Avatar
Default Swap start up problems
Hey everyone, NOOB here. I just swapped a d15b vtec into my 94 dx. The only thing I have not hooked up yet is the vtec solenoid and my p28 ecu. I go to start up the car and it is really boggy, when I give it gas it boggs and dies out. Any help would be awesome. Thanks
Old Oct 27, 2007 | 12:16 PM
instrument's Avatar
sounds like timing to me
check your firing order homeslice
Old Oct 27, 2007 | 01:11 PM
VtecVillan's Avatar
I took the plugs out of the distributor and tried doing the 1, 3, 4, 2 and went to start the car and now there is nothing, not even a crank, so I did something wrong. Now I probably just toasted my motor
Old Oct 27, 2007 | 03:45 PM
Inliner's Avatar
check your battery connections before you do anything, make sure the little clip on the starter is plugged in as well.
Old Oct 27, 2007 | 04:01 PM
mustang5.slow's Avatar
* B A N N E D *
Default Re: (Inliner)
to me it kind of sounds like you have you tps and map connected wrong.
you should check up on that.
Old Oct 27, 2007 | 04:21 PM
VtecVillan's Avatar
Thanks alot for your help. It was the tps and map sensors were hooked up backwards. New problem though, when I let the clutch out though a soft grinding noise. That isnt good, brand new clutch/flywheel. I think we need to maybe bleed the clutch before we run it. Thanks again guys!
Old Oct 27, 2007 | 05:18 PM
* B A N N E D *
Default Re: (VtecVillan)
good to hear i helped. well good luck
if you have any more issues make a new thread.
user 72397823
Dec 21, 2015 12:34 PM
gilbert90605
12
Apr 13, 2010 09:17 AM
CiViC_SOHC
May 29, 2007 06:31 PM
i hate rice
19
Jun 25, 2006 12:49 PM
t3to4e
Dec 14, 2003 08:40 AM
