car wont start?
i started my car this morning and it turned on fine and den all of a sudden my car just turns off..i tried starting it back up wut it wont turn on..i checked the spark plug and the spark plug wires but nothing..also i check if i had any burnt fuses but nothing..all dat is fine...please i need help..any suggestions..thank you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by em1_fox »</TD></TR><TR><TD CLASS="quote">i started my car this morning and it turned on fine and den all of a sudden my car just turns off..i tried starting it back up wut it wont turn on..i checked the spark plug and the spark plug wires but nothing..also i check if i had any burnt fuses but nothing..all dat is fine...please i need help..any suggestions..thank you</TD></TR></TABLE>
when you turn the key to the on position (right before you start it), do you hear a humming noise from the back seat?
maybe you main relay is bad, this controls the fuel pump.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by em1_fox »</TD></TR><TR><TD CLASS="quote">ya i heard dat noise..</TD></TR></TABLE>
ok, so the car started then turned off? when was the last time you had a tune up?
tune up, replacing:
fuel filter
dist. cap
dist. rotor
plugs
wires
tune up, replacing:
fuel filter
dist. cap
dist. rotor
plugs
wires
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by em1_fox »</TD></TR><TR><TD CLASS="quote">fuel filter
dist. cap
dist. rotor were r all these located at..</TD></TR></TABLE>
fuel filter is located on the firewall. just follow the fuel line on the left of the fuel rail. it'll run left to right from the rail to the wall.
the dist. cap, rotor and wires are located on the distributor. it is on the left of the motor on top. your spark plug wires run from it to the top of the motor.
dist. cap
