timing question, rear balancer shaft...
Old Oct 27, 2007 | 10:18 AM
hondaZvic's Avatar
Default timing question, rear balancer shaft...
ok, so i put the long bolt in there to hold the rear shaft still while i put the belt on... but, i found that the bolt went in there more than 1 way...
sooo... i looked at the shaft, and noticed these 2 markings on it.. 1 was a circle on the actual gear, and the other was a triangle notch on the plate behind the gear... with the bolt in, does it matter which one of these is where??
sorry for the blurry pix, for some reason my camera wont focus well up close.
Old Mar 24, 2008 | 08:27 PM
jdward's Avatar
Default Re: timing question, rear balancer shaft... (hondaZvic)
Did you ever get a definate answer to this question? I have run into the same situation.
Old Jun 3, 2008 | 10:24 PM
JDM turbo DC's Avatar
476 whp / 323 tq @ 17 PSI
Default Re: timing question, rear balancer shaft... (jdward)
resurrecting this thread because i am in the middle of the same thing with my daily driver. someone answer
Old Jun 4, 2008 | 05:56 AM
Mr Yamada's Avatar
I believe that Mr Hondadude posted a picture, not long ago, showing the dot on the rear pulley lines up with a casting boss at about the 5 'O' clock position.
It looks like in the picture that the oil pump seal is leaking.
It is a very thin seal and gets hardened and shrinks from repeated heat/cool cycles.
Old Jun 4, 2008 | 05:24 PM
gianinline's Avatar
no answer yet. Will it really matter if the dot isn't ligned up?????
Old Jun 6, 2008 | 12:10 PM
spoonfedcrx's Avatar
Default Re: (gianinline)
like yamada said. line that dot up with the boss on the block. and yes u want those in the position.
wrench123
May 18, 2015 09:37 AM
civic_loner22
Mar 17, 2011 05:46 PM
Icemanxxxv
Oct 17, 2005 09:48 AM
Zcarninja
Dec 14, 2003 08:46 PM
D15B7
Oct 18, 2002 02:03 PM
