Drag Strip 2nite...Have some ?
I have a 94 DC2 with I/H/E
On konis/hr sports
I should set my suspension soft in the front and stiff in the back?
1. what rpms should i try launching at?
any advise would be great, trying to get a good 60'
2. What does feather the clutch mean and how do you do it?
Ive read about this but dont undestand it
thnks
On konis/hr sports
thnks
Play with tire pressure and suspension settings from run to run.
What rpm to launch at really depends on a lot of conditions.
I would recommend starting at 3800 rpms and working your way up as needed etc.
all the way stiff in back, front is variable
i like 4k
the launch is everything. i dont burn out on street tires, its been proven not to help.
this is my understanding, i launch at 4k and let go of my clutch pedal half way while holding my rpm at 4k with the gas untill i feel traction. then i gradually give more gas and let go of the clutch trying to stay just on the brink of traction.
if i get traction too quick at 4k i raise it accordingly.
idk if that answered your question really but i pull better times than most my friends by the 60' in their cars. for example i pulled a 2.0 60' in my old 99' civic CX hatch stock at sea level.
good luck and try new things. there is a million ways to launch well..
i like 4k
Go around the water in the burnout area.
Spin your street tires for a second to clear out the tread (get the stones out).
Hold your Revs at ~4k.
Slip the hell out of your clutch to get going. You want to get moving a fast as possible without wheel-spin.
Wear your seatbelt, and have fun!!
boosted91crx
Apr 10, 2010 02:52 PM
