4.40 ring gear swap
Old Oct 27, 2007 | 07:37 AM
amadriga's Avatar
Default 4.40 ring gear swap
Hello
Can I swap a 90-91 4.40 ring gear into a 92-93 LS (4.26) tranny?
Thanks!
Old Oct 29, 2007 | 08:01 AM
amadriga's Avatar
Default Re: 4.40 ring gear swap (amadriga)
anyone?
Old Oct 29, 2007 | 12:15 PM
hatchling37's Avatar
Yes, but you need another differential. The 4.40 won't bolt up to the LS diff.
Old Oct 30, 2007 | 12:19 PM
White98LS's Avatar
Default Re: 4.40 ring gear swap (hatchling37)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchling37 &raquo;</TD></TR><TR><TD CLASS="quote">Yes, but you need another differential. The 4.40 won't bolt up to the LS diff.</TD></TR></TABLE>
Not sure about the cable trannies, but on the '94-01 hydro LS tranny you can use a 4.40 B16 ring gear on the LS diff, same bolt pattern.
Old Nov 20, 2007 | 09:48 PM
_oemek_'s Avatar
Default Re: 4.40 ring gear swap (White98LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White98LS &raquo;</TD></TR><TR><TD CLASS="quote">
Not sure about the cable trannies, but on the '94-01 hydro LS tranny you can use a 4.40 B16 ring gear on the LS diff, same bolt pattern.</TD></TR></TABLE>
Do the notches on the final drive ring gear have to match with the countershaft gear? are they matched sets.
Old Nov 20, 2007 | 11:13 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: 4.40 ring gear swap (_oemek_)
YES, they are matched sets.. you can not just swap it in without changing the countershaft too..
Old Nov 21, 2007 | 06:16 AM
_oemek_'s Avatar
Default Re: 4.40 ring gear swap (sanimalp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sanimalp &raquo;</TD></TR><TR><TD CLASS="quote">YES, they are matched sets.. you can not just swap it in without changing the countershaft too..
so if there was two notches. you cant just swap it to a gear with 3 notches.
madcrx69
Transmission & Drivetrain
Mar 23, 2009 06:38 PM
scspeed
Mar 10, 2009 10:13 AM
jdub01
Aug 2, 2007 10:49 PM
biggdogg
Jan 5, 2005 09:19 PM
