Rear Disc Brake Swap Question
Old Oct 27, 2007 | 05:48 AM
LSej1's Avatar
Default Rear Disc Brake Swap Question
I have a 95 Civic EX Coupe and a 95 Civic LX 4door. The 4door has rear disc on it and i was wondering if i can swap that rear disc over to the coupe without any major problems?
EDIT: WOULD IT BE EASIER TO REMOVE THE DRUM BACKPLATE AND BOLT UP THE DISC? OR DO I HAVE TO REMOVE THE ENTIRE TRAILING ARM ASSEMBLY?
Modified by LSej1 at 4:26 PM 10/28/2007
Old Oct 27, 2007 | 06:08 AM
daluv's Avatar
Default Re: Rear Disc Brake Swap Question (LSej1)
Yes you can.
Old Oct 27, 2007 | 06:17 AM
B18bEG6ick's Avatar
Default Re: Rear Disc Brake Swap Question (daluv)
i thought EX's and SI's have rear disc brakes?
Old Oct 27, 2007 | 06:27 AM
daluv's Avatar
Default Re: Rear Disc Brake Swap Question (B18bEG6ick)
I know it was an option from the factory for the EX, and was stock on the SI's.
Old Oct 27, 2007 | 07:28 AM
hondajav06's Avatar
Yes u can, i did it and it was very easy!
Old Oct 27, 2007 | 10:39 AM
sleepyH22's Avatar
not meaning to threadjack..but..
Will a 94-01 4 DOOR integra rear disk knuckles fit a 92-95 civic hatch? i have a92 hatch and found a 97 4 dr teggy with only one good side for the disk brake knuckle, the right side of the car is totalled and he only wants 40 dollars for the one knuckle.
Old Oct 27, 2007 | 11:46 AM
95vxtealhatch's Avatar
1992-1995 civic's and 94-01 integra's have the EXACT same suspension, not only that but they are practically the same car.
To my knowledge suspensions are still the same on the 4 door tegs. I don't know a reason why they wouln't bolt on.
Old Oct 27, 2007 | 11:54 AM
g0rg0n's Avatar
https://honda-tech.com/zerothread?id=1811368
Search is your friend.
Old Oct 27, 2007 | 11:58 AM
EG8GSR's Avatar
i just did mine yesterday from a 01 teg to 95 EG there all the same takes about an hour
good luck
[713]
Texas -OK -LA (Sales)
Mar 7, 2012 05:42 PM
Maluko
Suspension & Brakes
Apr 30, 2009 06:14 AM
ke98248
Oct 21, 2008 09:49 PM
JaydmEg
Aug 11, 2008 08:49 PM
JaydmEg
Aug 11, 2008 08:37 PM
