turbo integra b18c5 burning alot of oil not sure why really need help
Old Oct 27, 2007 | 02:46 AM
1998turboR's Avatar
Default turbo integra b18c5 burning alot of oil not sure why really need help
I am not sure what you would like to know about my car but i am ready to answer any ?s to help solve my problem. The first thing is it burns alot of oil at least 1 qt a week which just cant be right. Its rebuilt motor sleeved cp piston pauter rods valve job springs retainers, arp head studs hondata s200 w boost . the car is tuned to about 10 lbs and makes about 320whp. it has a slight ticking noise which my friend believes is the lifters needed to be adjusted. i use 2050 oil and still burn so much. when i start the car up a cloud of smoke come out but when its warm it seems to be fine i have a 3 inch exaust with no cat or anything on it i saw a post on another website talking about valve seals and thought maybe thats it Can anyone help me the turbo kit is from drag
Old Oct 27, 2007 | 02:48 AM
xenocron's Avatar
Default Re: turbo integra b18c5 burning alot of oil not sure why really need help (1998turboR)
Compress test and leak down test?
Does it smoke blue under heavy acceleration or deceleration?
Old Oct 27, 2007 | 02:57 AM
1998turboR's Avatar
Default Re: turbo integra b18c5 burning alot of oil not sure why really need help (xenocron)
i do not believe it smoke at all after the start up and as for the leak down and compression i have not done that yet but i will this tues what should i check if those are both ok
Old Oct 27, 2007 | 03:04 AM
xenocron's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1998turboR &raquo;</TD></TR><TR><TD CLASS="quote">i do not believe it smoke at all after the start up and as for the leak down and compression i have not done that yet but i will this tues what should i check if those are both ok </TD></TR></TABLE>
If compression and leak down are good and there is no smoke...you have an oil leak
Old Oct 27, 2007 | 05:20 AM
kyden's Avatar
it could possibly be valve seals. does it smoke on decel?
Old Oct 27, 2007 | 10:16 AM
blackeg's Avatar
Default Re: turbo integra b18c5 burning alot of oil not sure why really need help (kyden)
my car used to smoke on startup, and when i would start driving it after idling for a while. it was the valveseals.
do a compression and leakdown test, they will give you more info.
hows your coolant level?
superslow-oto
Jun 11, 2008 10:57 AM
bigempty12
Mar 11, 2008 07:01 AM
KiddEng
Jan 17, 2006 07:12 PM
HT Username
19
Apr 14, 2005 01:04 PM
bundy
Nov 19, 2002 09:04 PM
