eg front end
Old Oct 26, 2007 | 11:31 PM
bigandy90's Avatar
Default eg front end
how do u make it so there is no gap between my light and bumper someone told me there is like a braket or something that i might be missing any ideas
Old Oct 26, 2007 | 11:32 PM
Zaakro's Avatar
Default Re: eg front end (bigandy90)
ummm I think you have this is the wrong place.
Old Oct 27, 2007 | 12:37 AM
loudandlow's Avatar
Default Re: eg front end (Zaakro)
There is a bumper spacer that bolts to the top of the reinforcement on each side under the headlights. Get them from a junk yard or from the dealer, they are cheap.
Oh, and this is the ef forum, please find your way to the eg forum, one link below this one from the home page. Also please forget how to get back. Thank you.
Old Oct 27, 2007 | 12:52 AM
ef yu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zaakro &raquo;</TD></TR><TR><TD CLASS="quote">ummm I think you have this is the wrong place. </TD></TR></TABLE>
X2?? the F&G are near each other on the keyboard. must have been a typo..if not
Old Oct 27, 2007 | 03:34 AM
CRX Toad's Avatar
Moved from CRX forum
Old Oct 27, 2007 | 06:39 AM
daluv's Avatar
Default Re: eg front end (loudandlow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loudandlow &raquo;</TD></TR><TR><TD CLASS="quote">Oh, and this is the ef forum, please find your way to the eg forum, one link below this one from the home page. Also please forget how to get back. Thank you.</TD></TR></TABLE>
This is the 92-00 Civic forum, and he is asking about a 92-95 civic, in which this is the correct forum to do so in.
Old Oct 27, 2007 | 07:01 AM
1992Si's Avatar
Sounds to me like your saying there is a space between the urethane bumper and the head light. There is always a gap there. The bracket people are talking about is not going to make the gap go away. I removed those brackets years ago. If you want to try and close the gap loosen the two bolts and two nuts that hold the head light assy and try and move the light forward and down. But you'll have to adjust the height after you do that.
Do you have a photo of what your talking about?
Have both bracket removed in this photo from a few years back.
Old Oct 27, 2007 | 01:14 PM
NOFX's Avatar
H-T White Ops
Default Re: eg front end (daluv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daluv &raquo;</TD></TR><TR><TD CLASS="quote">?????
This is the 92-00 Civic forum, and he is asking about a 92-95 civic, in which this is the correct forum to do so in.</TD></TR></TABLE>
Read the post above yours... He posted this in the EF section first. A mod moved it from there to here.
Old Oct 27, 2007 | 02:54 PM
stock_honda_coupe's Avatar
Default Re: eg front end (NOFX)
Pretty sure this section is for EGs and EKs. Any way, I've heard of people removing the plastic clip and screw, and putting a bolt in there instead.
Old Oct 27, 2007 | 02:59 PM
NOFX's Avatar
H-T White Ops
Default Re: eg front end (stock_honda_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock_honda_coupe &raquo;</TD></TR><TR><TD CLASS="quote">Pretty sure this section is for EGs and EKs. Any way, I've heard of people removing the plastic clip and screw, and putting a bolt in there instead.</TD></TR></TABLE>
It is. This thread was originally in the EF section. It was moved here. The posts saying that it doesn't belong in the section it was posted in were posted when this thread was in the EF section.
This thread does not belong in the EF section, like they said.
Old Oct 27, 2007 | 03:12 PM
jasoncrashtech's Avatar
bumper stiffeners are bolted with two 10mm bolts to the bumper reinforcement bar.
Old Oct 27, 2007 | 03:43 PM
instrument's Avatar
ohhh something shiny!
Old Oct 27, 2007 | 05:50 PM
bigandy90's Avatar
i am pretty sure this this is the 92-00 forum so i dont know what you are talking about and it doesnt take 10 people to tell me that but thinks for your guys help that told me the problem
Old Oct 27, 2007 | 06:55 PM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigandy90 &raquo;</TD></TR><TR><TD CLASS="quote">i am pretty sure this this is the 92-00 forum so i dont know what you are talking about and it doesnt take 10 people to tell me that but thinks for your guys help that told me the problem </TD></TR></TABLE>
*sigh...*
THIS MEMBER IS FROM THE EF SECTION AND IS POINTING OUT THAT AT THE TIME THAT HE POSTED, THIS THREAD WAS IN THE EF SECTION TOO.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loudandlow &raquo;</TD></TR><TR><TD CLASS="quote">There is a bumper spacer that bolts to the top of the reinforcement on each side under the headlights. Get them from a junk yard or from the dealer, they are cheap.
THIS MEMBER ALSO IS FROM THE EF SECTION AND POINTS OUT THAT THE OP POSTED THIS ORIGINALLY IN THE EF SECTION.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">Moved from CRX forum</TD></TR></TABLE>
THIS IS WHEN THE MOD IN THE EF SECTION MOVED THIS THREAD FROM THE EF SECTION TO THE EG/EK SECTION WHERE IT IS NOW!
Jesus people. Read the thread. The thread was posted in the wrong section. A mod moved it here. That's why its in the right section now.
Old Oct 27, 2007 | 08:41 PM
BrakeExpert's Avatar
Default Re: (1992Si)
That bumper isnt any better, hes just got a broken hood with a much bigger gap.
J-Spot
Nov 21, 2005 07:36 PM
hale_image
May 4, 2005 05:28 PM
japspecnegro
Mar 18, 2005 10:54 PM
WannabeEF9
Jan 13, 2005 04:41 PM
supaZZZleepa
Oct 26, 2004 07:26 PM
