2001 GSR fouling the plugs and hard to start
Old Oct 26, 2007 | 08:58 PM
mecaneck77's Avatar
Default 2001 GSR fouling the plugs and hard to start
Any ideas? The main engine ground was left off for @9 months and it was hard to start in the am only at first. I found the ground strap hanging and I re-connected it. I have replaced the map sensor, distributor, cap, rotor, wires, plugs(twice), and I still have the same problem. I have checked the tps signal, ect signal, iat signal, and so on. The thing runs like the timing belt is off a tooth only on initial start-up. If you kepp the revs up untill it has warmed up a bit it will idle and run but has low power. Also it smokes a lot and runs super rich when it is cold. I checked the compression and it is all good. WTF
Any help would be sweet.
Thanks
Old Oct 27, 2007 | 05:49 AM
King V's Avatar
Default Re: 2001 GSR fouling the plugs and hard to start (mecaneck77)
You may have a sticky/gummed injector(s) from it sitting.
Old Oct 27, 2007 | 07:52 AM
mecaneck77's Avatar
Default Re: 2001 GSR fouling the plugs and hard to start (King V)
No, I pulled the fuel rail off and fired off the injectors. The spray pattern was perfect and they didn't leak...............
yoffer
12
Apr 4, 2014 11:48 PM
Lan
Jan 2, 2013 06:45 AM
mecaneck77
Nov 17, 2007 07:18 AM
