help on conversion from automatic to manual
Old Oct 26, 2007 | 07:43 PM
SNAX's Avatar
Default help on conversion from automatic to manual
i have a 98 civic ex which is automatic. i bought a b18b but it came out of an automatic integra. i have a manual ls transmission what do i need to do...to convert it from auto to manual??? and is it worth it??
Old Oct 27, 2007 | 09:43 AM
bigkvn77's Avatar
Default Re: help on conversion from automatic to manual (SNAX)
clutch pedal assembly
clutch master cylinder
clutch slave cylinder
clutch line
shift linkage
clutch assembly
You also need a manual ecu.
Usually cost some where in the ball park of $300 - 400.
The way I see it you have the bulk of the parts. I belive it would be worth it.
Old Oct 27, 2007 | 02:34 PM
hatchling37's Avatar
Default Re: help on conversion from automatic to manual (bigkvn77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigkvn77 &raquo;</TD></TR><TR><TD CLASS="quote">The way I see it you have the bulk of the parts. I belive it would be worth it.
Indeed. You've got the expensive stuff already, it's pretty easy to complete it.
Old Nov 2, 2007 | 04:29 PM
SNAX's Avatar
yea i have a gsr tranny i got most of all the stuff u just said but i taught i could use the auto... ecu? and also im going to be boosted so far i bought a gasket set and timing and further more... what else should i do?
OuToFoCuZ
23
Dec 1, 2006 11:02 AM
jjohn6438
Honda Civic (2001 - 2005)
29
Nov 28, 2006 04:12 PM
itrcrazy
Jan 26, 2006 05:26 PM
blue_hatch
Mar 17, 2005 10:45 PM
tegra33
Sep 23, 2004 08:07 PM
