Rear wiper plug part #?
Old Jun 21, 2002 | 04:33 PM
Dirt's Avatar
Default Rear wiper plug part #?
Any of you remove your rear wiper assembly?
I need the rear wiper plug part number and anything else to complete the job.
This is specifically for a G2, but I think it may be very similar for G3s. Thanks.
Old Jun 21, 2002 | 04:39 PM
Dirt's Avatar
Default Re: Rear wiper plug part #? (Velvet Jones)
This is the link to the procedure..... http://www.g2ic.com/tegtips/exterior/16.html
Problem is with this part number in the above link. Two local dealers cannot find that part number!
[Modified by Velvet Jones, 5:44 PM 6/21/2002]
Old Jun 21, 2002 | 04:51 PM
Junior_r's Avatar
Plug 90301-SR3-000
Old Jun 21, 2002 | 04:52 PM
Jason's Avatar
Part numbers needed for conversion...
90301-SR3-000 Plug
90156-SH3-000 Bolt
94103-14200 Washer
76707-ST7-000 Grommet
Old Jun 21, 2002 | 05:04 PM
Chalupa R's Avatar
Default Re: Rear wiper plug part #? (Jason)
All i needed for the conversion was the plug. dohcsidesi did it for me and used the original hardware from the wiper.
ej-what would he need a rear wiper for if the r never sees rain
[Modified by b18c5dc2, 2:05 AM 6/22/2002]
Old Jun 21, 2002 | 05:07 PM
Dirt's Avatar
Default Re: Rear wiper plug part #? (b18c5dc2)
Upon further review, local dealers who seem to have no clue
Hopefully a call to A&H on Monday
Old Jun 21, 2002 | 05:28 PM
Dodger2940's Avatar
My brother did this for his GSR.Go to Lowes and get a 2 inch elevator bolt, it is black and has a flat top on it. Also get a washer that the bolt can run through and a wing nut that will fit the bolt. Remove the wiper and the motor. Leave the black rubber cap that is on the window. Run the flat black bolt through the hole and place the washer on the other end and tighten it up with the wing nut. Works just like the kit from Honda. Only cost about 2 bucks for parts and so far it has been water proof.
Old Jun 21, 2002 | 05:55 PM
yellow blur's Avatar
Default Re: Rear wiper plug part #? (Dodger2940)
99 cents for 4 grommets at home depot.
dVeLoPe
Sep 4, 2004 05:46 PM
Integra4lyfe
Dec 23, 2003 10:46 PM
Integra_B18B
May 23, 2002 05:50 AM
Random.Hero
Dec 28, 2001 07:56 PM
