4th gen lude overheats at idle but fans work?
Old Oct 26, 2007 | 02:25 PM
redline7's Avatar
Default 4th gen lude overheats at idle but fans work?
Well my car overheats at idle but the fans does come on. I timed them and at normal temp. They come on for about 30 seconds and about every 2 minutes. However the fans never come on when I turn on the ac nor do they come on when the car is turned off after overheating. I have tried using a civic radiator I had with a new cap and still the same thing. I changed the t-stat and the radiator fan switch on the thermo. My coolant level is full and the system has no air in it. I am thinking bad waterpump?
Old Oct 26, 2007 | 03:45 PM
AndyD's Avatar
Default Re: 4th gen lude overheats at idle but fans work? (redline7)
The fans don't really do much. That's not the problem.
How long does it take for it to start overheating?
A few quick things to check/change:
Thermostat
Bleed the coolant
The thermostat would be the first thing I would change.
Old Oct 26, 2007 | 04:08 PM
cb7tougeracer's Avatar
Default Re: 4th gen lude overheats at idle but fans work? (AndyD)
thermostat or a air in the coolant lines
adobospoon
May 31, 2014 06:05 AM
denracho
Dec 31, 2009 10:45 PM
stevenDAtegra
Jul 23, 2009 12:32 PM
illicit^
14
Jul 5, 2007 10:09 AM
Mr. 1582
Nov 7, 2003 03:43 PM
