asking for some assistance.. h22 swap in 6th gen
ok just so i dont get flammed i did search here and everywhere else. but i have come to the conclusion that there arent any made for this car. i have an 01 accord sedan with an h22 swap. i was just wondering if there are aftermarket motor mounts made for this car. i know i can use the drivers side mount off a prelude but what about the other 3. hope i can get help from u guys. thanx.
heres a good log of what a friend of mine went through when he swapped a h22 into his 6th gen
http://www.everything-honda.co...=3843
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jweller »</TD></TR><TR><TD CLASS="quote">heres a good log of what a friend of mine went through when he swapped a h22 into his 6th gen
http://www.everything-honda.co...=3843</TD></TR></TABLE>
thanx. that was a good write up. but ya im sorry i already have my motor in i was just wondering what after market motor mounts i can use. i just wanna be 100% sure what fits i dont really feel like buying mounts that wont fit. just to share heres a picture of my car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by o2 jockey »</TD></TR><TR><TD CLASS="quote">
Here is a write up I found that has more info on the mounts.
https://honda-tech.com/zero...73019
Nevermind I just re-read and it looks like he used the stock mounts not aftermarket.
One more that might help:
http://www.everything-honda.co...age=7
Here is a write up I found that has more info on the mounts.https://honda-tech.com/zero...73019
thanx again for those links. but is there any body with an h22 in a 6th gen using after market mounts?
Modified by o2 jockey at 1:09 AM 10/28/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by o2 jockey »</TD></TR><TR><TD CLASS="quote">thanx again for those links. but is there any body with an h22 in a 6th gen using after market mounts?
AFAIK, nobody makes aftermarket mounts for that swap. If you are looking for stiffer mounts than OEM, you'll either have to fill them with polyurethane or fabricate them yourself.
AFAIK, nobody makes aftermarket mounts for that swap. If you are looking for stiffer mounts than OEM, you'll either have to fill them with polyurethane or fabricate them yourself.</TD></TR></TABLE>
AFAIK? but thanks mann i pretty much figrued. i just needed to hear it from somenoe else.
AFAIK? but thanks mann i pretty much figrued. i just needed to hear it from somenoe else.</TD></TR></TABLE>
As Far As I Know.
As Far As I Know.
