honda newb working on mini me
Old Oct 26, 2007 | 12:45 AM
bdb_86's Avatar
Default honda newb working on mini me
so i have a 1990 honda civic with the D15?? and im looking to do a mini me swap and also convert it to manual transmission and multi port fuel injection so i will be in need of a new obd-0 ecu that i have already purchased but now im not sure if i got the right one. the ecu that i purchased is for a D16a6 is that a vtec engine or not i was told that it was but after reading a few articles im not so sure it is
Old Oct 26, 2007 | 02:27 AM
ef yu's Avatar
Default Re: honda newb working on mini me (bdb_86)
D16a6 = SOHC nonvtec
D16z6 = SOHC vtec .
you were dooped by the seller. look on the side of the ECU. it should read somthing PM6 somthing. as for the converting to MPFI. just search it up. you'll find PLENTY. not sure about the auto to manual converting. never done it. nor do i want to. id rather buy a MT honda civic becuase its that cheap.
Old Oct 26, 2007 | 08:54 AM
bdb_86's Avatar
Default Re: honda newb working on mini me (ef yu)
it was my fault, the seller didn't really verify if it was for a vtec engine or not and i could have done my research a little more he said it was for a 88 crx SI and i thought the SI came with a vtec engine on the side of the ecu it says PM6-A041
this was the auction
http://cgi.ebay.com/ebaymotors...&rd=1
so was there a vtec engine that ran obd-0?
and as for converting to a manual me and a buddy of mine did it on his 93 hatch it was rather simple
Old Oct 26, 2007 | 09:14 AM
Hanmin's Avatar
obd0 = carb engines? yes no?
Old Oct 26, 2007 | 10:09 AM
89efDUSTY's Avatar
Default Re: (Hanmin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hanmin &raquo;</TD></TR><TR><TD CLASS="quote">obd0 = carb engines? yes no?</TD></TR></TABLE>
d16a6 is Obd0 and is PGMFI so no please search
D15A3 is also PGMFI
d15a2 is Carbed
Old Oct 26, 2007 | 12:16 PM
ef yu's Avatar
Default Re: (89efDUSTY)
first gen B16A ran OBD-0
Old Oct 26, 2007 | 12:42 PM
whiteknightef's Avatar
Default Re: (ef yu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef yu &raquo;</TD></TR><TR><TD CLASS="quote">first gen B16A ran OBD-0</TD></TR></TABLE>
obd-0 but not a pm6!!!!!!
Old Oct 26, 2007 | 12:47 PM
ef yu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bdb_86 &raquo;</TD></TR><TR><TD CLASS="quote">
YES. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef yu &raquo;</TD></TR><TR><TD CLASS="quote">first gen B16A ran OBD-0</TD></TR></TABLE>
Old Oct 26, 2007 | 12:48 PM
IT GUY's Avatar
Default Re: (whiteknightef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteknightef &raquo;</TD></TR><TR><TD CLASS="quote">
obd-0 but not a pm6!!!!!!</TD></TR></TABLE>
the OP was asking if there was an OBD0 engine that was vtec. The answer is yes, like ef yu posted. but you are right the pm6 is not a vtec ecu.
damn, you beat me to it ef yu.... lol
Old Oct 26, 2007 | 07:54 PM
bdb_86's Avatar
thanks for your guys's help so far but let me rephrase my question when i asked "was there a vtec engine that ran obd-0?"
i mean was there a <U>D series</U> vtec engine that ran obd-0?
and also what ECU would go with it
Old Oct 26, 2007 | 09:13 PM
Fuzzy Rhubarb's Avatar
Default Re: (bdb_86)
I don't know of any OBD0 VTEC D engines, but you could do the mini-me like you talked about. That would allow you to use OBD0 and have VTEC. As for the ECU, you could use the PM6 (with an MPFI modded harness) and trigger the solenoid with an RPM switch or chip your ECU to use the A/C clutch for VTEC.
Old Oct 26, 2007 | 09:40 PM
loudandlow's Avatar
Default Re: (Fuzzy Rhubarb)
convert to obd1, it's easy, better and it will help you immeasurably if you ever get it tuned. tuning an obd0 is a bitch. good luck with the swap
axis11
Dec 17, 2019 02:17 AM
Vtec Jourdain
Engine Management and Tuning
Jan 16, 2013 11:55 PM
d15civ
Dec 1, 2004 09:19 AM
sman21
Nov 15, 2004 04:24 AM
