B16A2 VS B16A2,VTEC PULLING LESS.
Old Oct 25, 2007 | 10:47 PM
baulum's Avatar
Default B16A2 VS B16A2,VTEC PULLING LESS.
Hi,i've a b16a2(92-95) running with a converting(A/T into M/T) jdm p30 ecu,obd1.Yesterday i raced against a b16a2(92-95) but running with obd2 wiring,usdm p2t ecu.I've a civic ek3 4dr and the boy drives a civic eg6 2dr.He overtook me on vtec engagement.I drove his eg,the vtec pulls much more harder than mine.And i'm very curious why my vtec does not pull the same?I agree that his car body is less weighted.But not to that extent of power?
Old Oct 26, 2007 | 12:34 AM
MF Doom's Avatar
trapped in my own room!
Default Re: B16A2 VS B16A2,VTEC PULLING LESS. (baulum)
is your vtec fluid is low?
Old Oct 26, 2007 | 01:35 AM
Frozen E's Avatar
H-T White Ops
You're comparing two different engines in two different cars and wonder why they're not the same?
Old Oct 26, 2007 | 03:35 AM
realdealryan's Avatar
Your car is heavier. Autos have a different cam profile, right? Go get some stock GSR cams (somebody you know probably has them) and take your back seat out if you must.
Old Oct 26, 2007 | 03:38 AM
baulum's Avatar
Default Re: B16A2 VS B16A2,VTEC PULLING LESS. (MF Doom)
How will I check the vtec fluid?Engine oil?
Old Oct 26, 2007 | 03:41 AM
baulum's Avatar
Default Re: B16A2 VS B16A2,VTEC PULLING LESS. (realdealryan)
Can you specify an auto cam profile and a manual one?What is their opening and closing duration.....
Old Oct 26, 2007 | 03:46 AM
yoffer's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baulum &raquo;</TD></TR><TR><TD CLASS="quote">How will I check the vtec fluid?Engine oil?</TD></TR></TABLE>
Are we serious?
Old Oct 26, 2007 | 03:47 AM
yoffer's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by realdealryan &raquo;</TD></TR><TR><TD CLASS="quote">Your car is heavier. Autos have a different cam profile, right? Go get some stock GSR cams (somebody you know probably has them) and take your back seat out if you must.</TD></TR></TABLE>
No.
Old Oct 26, 2007 | 03:48 AM
baulum's Avatar
Yo man,really serious..
Old Oct 26, 2007 | 03:53 AM
yoffer's Avatar
Banned
lol. There is no such thing as vtec fluid. That guy was playing around with you. But the other guy that was talking about cams doesnt know his left from his right. The difference between and auto and a manuel is the transmission. The motor is the same. And he said that your friend has GSR cams, idk if he took a look around lately, but they're not that easy to find and when you do find some, theres a hefty price tag.
Old Oct 26, 2007 | 03:54 AM
baulum's Avatar
can you differentiate between an auto b16 cam profile and an m/t cam profile?i'm highly interested to know because the eg leaves me thrice a car.
Old Oct 26, 2007 | 03:55 AM
yoffer's Avatar
Banned
What did i just say? I just said that the ONLY difference between a manuel and a automatic is the TRANSMISSION. The motor is the same.
Old Oct 26, 2007 | 03:59 AM
baulum's Avatar
But why the eg overtook me as he has the same engine,but he is running with a p2t ecu?do you think this is the fact?And also any suggestions about the vtec engagemnt?mine pulls less than his eg?
Old Oct 26, 2007 | 04:04 AM
yoffer's Avatar
Banned
Idk, all motors are different, even if they are the same model. There are all kinds of different variables on why it is faster,broken in better,up to date on oil changes/maintnence ect... Are you sure that there are no modifications done to his car? And a p2t ecu comes out a 96-00 civic EX with a d16y8.
Old Oct 26, 2007 | 04:10 AM
yoffer's Avatar
Banned
O and weight also plays a factor in who won. Your four door weighs a lot more than his 2dr. Dont believe that since you have the same motor as him that your going to beat him. I dont know exactly what the weight difference is, but i could guess that its close to 400/600lbs.
Old Oct 26, 2007 | 04:12 AM
baulum's Avatar
u r wrong,only b16 96-99 which uses p2t.But the eg has a 2nd gen b16 which should be used a p30 ecu.but his engine runs with a p2t ecu,that is obd2.do you think using a different wiring and ecu has an effect on power?
Old Oct 26, 2007 | 04:17 AM
baulum's Avatar
This is the core of the advantage on those who have lighter cars.I totally agree with you.Suppose i move on a buddy club camshafts spec4 package,do you think this will help me out to win a such race?
Old Oct 26, 2007 | 04:18 AM
deerman2701's Avatar
Default Re: (baulum)
This thread makes me laugh.
Old Oct 26, 2007 | 04:21 AM
baulum's Avatar
because you run a better engine than me.
Old Oct 26, 2007 | 04:22 AM
yoffer's Avatar
Banned
no im not, i have a 99 civic EX with the p2t ecu. i have a d16y8. instead of calling me a liar. why dont you use your search button at the top of the page? you obvisously dont know what the expletive your talking about because if you did i wouldnt be reading this thread. The ecus that are made for the b16, are pr3,p30,pct,and the pw0. Dont ever question what i know when you know nothing.
Old Oct 26, 2007 | 04:30 AM
baulum's Avatar
p2t ecu also is included.Anyway i'm suffering from headache just because the eg's vtec pulls much more harder than my vtec.Do you think a converted p30 ecu will deliver the same power comparing a stock m/t p30 ecu?
Old Oct 26, 2007 | 04:33 AM
Probot's Avatar
well the best way to make your vtec pull harder is to the tap the switch under the seat 3 times and buy the jdm powerband that goes in the engine bay
Old Oct 26, 2007 | 04:34 AM
yoffer's Avatar
Banned
No the p2t is not included. It is the ECU for a d16y8, not a b16. If you want to aurgue about, then prove to me that the p2t is for a b16. Auto's are slower in acceration than m/t's are anyway.
Old Oct 26, 2007 | 04:36 AM
yoffer's Avatar
Banned
Default Re: (Probot)
hahaha!!
Old Oct 26, 2007 | 04:37 AM
baulum's Avatar
What do you actually mean by seat and powerband?
