Spoon Brake Question?
Old Jun 21, 2002 | 02:25 PM
ITRaholic's Avatar
Default Spoon Brake Question?
Im going to buy new brake rotors and brake pads for my car (front and rear)
and i was wondering about the Spoon toys?
anyone have any experience of those..
and those?...
And if you work at or Own a Store/shop what would i have to pay for this setup
Thanks
Old Jun 21, 2002 | 03:02 PM
ITRaholic's Avatar
Default Re: Spoon Brake Question? (RedintegraR)
Please! i know there must be someone here who owns those.....
Old Jun 21, 2002 | 03:19 PM
Flux's Avatar
I don't own either, but I can tell you what verybody will say:
Don't bother with the pads, you can get better for cheaper and for your specific driving style and intended uses. You need first do a search on brake pads in this forum and over in the Road Racing/Autocross forum. Then tell us what you will be using them for....
The Spoon rotors are nice - a long arguement about slotted rotors will then follow with a mojority of people recommending getting Brembo blanks. I personally like the Spoon rotors and will probably get a set soon enough, even though they probably make little difference over OEM rotors.
Old Jun 21, 2002 | 03:44 PM
AJ PwR's Avatar
For the price, I will highly suggest you to go Endless
Old Jun 22, 2002 | 09:34 AM
ITRaholic's Avatar
Default Re: Spoon Brake Question? (Flux)
If i would go with brembo ony product that i would buy from them would be some
full Brake kit(calipers,rotors just everything)
i have heard that the Brembo rotors on stock caliper dont work as good as other aftermarked slotted rotors...Im a Spoon *****!
but now im goin to cheak out Endless at Aj racing...
Old Jun 22, 2002 | 06:46 PM
Willard's Avatar
Im a Spoon *****!
What is your indended use for these brakes?
Unless you have money to toss away... just get normal replacement rotors with a 'nice' pad (sutited for you use) and good brake fluid.
Mintex / Pagid / Textar... not sure what kinds of pads you have common access to.
Will
Old Jun 23, 2002 | 06:46 AM
ITRaholic's Avatar
Default Re: Spoon Brake Question? (Willard)
Daily driven most of the time but Auto-crossing on weekends.
ehh well where i live i have to pay as much for the OEM rotor than i got to pay for a aftermarked one...well really im not a spoon *****!!!
[Modified by RedintegraR, 7:47 AM 6/23/2002]
Old Jun 23, 2002 | 08:10 AM
jdmtyper680's Avatar
I have the spoon rotors - like RedintegraR said it is not a huge difference that can be noticed when driving on street but better track performance is the plus. I have heard endless and project mu brake pads work really well with these rotors. I would suggest brembo as another cost effective rotor. I've never used brembo though. I would actually like to by either buy the endless or project mu rotor - those seem to have a better design. Mugen has the best rotor with its design as it spins actually pulls air onto the rotor cooling it for street/track use. But the kit is 1200-1300 for the rotors and s2000 calipers thats all those are - call honda with the part# on the caliper and thats what theyll tell you. Well hopefully that helps you and others. Thanks Paul
Old Jun 23, 2002 | 10:56 AM
ITRaholic's Avatar
Default Re: Spoon Brake Question? (jdmtyper)
hey Jdm Type R is that your car in your avatar is so please can you post pictures?
Now im 80% sure of what products im going to buy those are:
Spoon Sports Slotted Brake Rotor and Endless Type NA-Y Brake Pads
Old Jun 23, 2002 | 11:37 AM
oz#227's Avatar
New User
Ventilated disc spin the hot air OUT not in.
But it might just be the way I read it. Cause when the Disc is spinning the heat raditates Out. That why Brake ducting points right at the Hub( the centre).
Just my 2c.
Later.
Old Jun 23, 2002 | 01:17 PM
976's Avatar
976
New User
Default Re: Spoon Brake Question? (oz#227)
Why not keep factory pads - Nissin - since they make spoon's s**t anyway.
Old Jun 23, 2002 | 01:20 PM
underrated99si's Avatar
get some crossed drilled and slotted rotors and some carbotech brake pads
Old Jun 23, 2002 | 01:58 PM
jimbob's Avatar
New User
Default Re: Spoon Brake Question? (underrated99si)
xdrilled rotors are for ppl who don't really know better. Slotted ones are good if u have more money to spend, but 40$ Brembo blanks are more than enough for even the most hardcore racers. Rotors are just wear and tear items. You don't get better braking by getting spoon/project mu or any other rotors for that matter. All anyone would be buying is the name of the spoon rotor and maybe a little more wear from them.
Spoon pads aren't that good. Endless are decent, but cost way too much to do the same job as others from Hawk, Carbotech, Porterfield, Performance Friction, etc... Don't buy parts just for the name, buy them for the performance. Buying expensive parts for your car but with no advantage other than using them to show off is nothing more than expensive rice...
Mugen112
Honda S2000
10
Jun 2, 2008 12:12 PM
sato1
Jul 23, 2007 12:03 PM
cume
Jun 15, 2007 09:51 PM
JDM SLICK
Jun 27, 2005 01:28 PM
itrsport.com
Jul 15, 2002 03:44 PM
