burnt clutch/ #
Old Jun 21, 2002 | 02:21 PM
RiCE On IcE 2's Avatar
Default burnt clutch/ #
anyone got a pic of a burnt ITR clutch and do u have the item # of a stock clutch?
Old Jun 21, 2002 | 02:53 PM
01PYITR's Avatar
Default Re: burnt clutch/ # (scmdl26)
Its not that burnt up but bad enough to slip in second, Hope this helps.
Old Jun 21, 2002 | 02:54 PM
Default Re: burnt clutch/ # (01PYITR)
how do u even tell if it's burnt neway lol
Old Jun 21, 2002 | 03:02 PM
Austin's Avatar
It has a really bad odor...at least that's the way that I do it....
Old Jun 21, 2002 | 03:06 PM
01PYITR's Avatar
Default Re: burnt clutch/ # (Austin)
the blue area is still ok but the red area is shinny and yes burnt
Old Jun 21, 2002 | 03:07 PM
01PYITR's Avatar
OH yeah that too
Old Jun 21, 2002 | 03:13 PM
oh i meant by looking at the plate lol.. I know u can smell it... neone have their clutch burn out aroudn 30000?
Old Jun 21, 2002 | 03:17 PM
01PYITR's Avatar
Mine went at 24,500 miles. I had just put Azenis on and tried to do a Quarter mile run at http://www.racewaypark.com and found out the hard way that the tires really stick Good at 26 psi.
What is your main question anyway?
Old Jun 21, 2002 | 03:23 PM
oh cus I'm getitng a new clutch.. righ tnow cus supposedly my old one was burned.. so I'm gonan ask to see the old one... and wanted to knwo wut to look for
Old Jun 21, 2002 | 03:54 PM
GZR4DR's Avatar
You can also check the springs on the clutch. If they are loose, it is time to get a new one anyways. Also if you see lots of debris in the clutch housing area that looks like wool or something it needs to be replaced. If you see large metal chunks it needs to be replaced.
Sorry i'm just remembering all the different things i've seen fall out of the clutch area after i removed a customers trans. Also check for hot spots on the pressure plate. That first pic has quite a few of them. They are the circle things. You can get the PP resurfaced, however i usually opt for replacing it. Flywheel should be resurfaced whenever you change the clutch as well. There should be no hot spots on it at all.
Old Jun 21, 2002 | 06:32 PM
Big Teggie's Avatar
Default Re: burnt clutch/ # (GZR4DR)
This what mine looked like when it finally went.
Old Jun 21, 2002 | 07:45 PM
SystemGSR's Avatar
Default Re: burnt clutch/ # (Big Teggie)
i wish i had pics of my stock one. I broke the pressure plate in 3 spots. Guys at Area 51 kept it for their collection. Guess it must not happen much.
Old Jun 23, 2002 | 03:15 PM
hooptie157's Avatar
damn!!!!!, *shaking head in disbelief*
Old Jun 23, 2002 | 03:32 PM
speedymon's Avatar
Default Re: burnt clutch/ # (hooptie157)
Holly crap!!! There's nothing there!
Old Jun 23, 2002 | 04:21 PM
Tweakmeister's Avatar
Default Re: burnt clutch/ # (speedymon)
looks like someone needed a new flywheel (big)!
I wish I had pictures of the clutch that went on my '96 RS. The clutch plate had shattered into pieces (went at 85mph..rev-matched to 4th and had to start out at two traffic lights with no clutch).
CKnight90
Oct 11, 2014 07:32 PM
sweetcarz02
Sep 30, 2004 04:20 AM
blufke
Aug 19, 2002 02:07 PM
jeebusm3
May 5, 2002 12:20 AM
