b16 crx axle bind issues need help
Old Oct 25, 2007 | 08:32 PM
strawberry's Avatar
Default b16 crx axle bind issues need help
i'm having problems with axle bind i was told i need 90-93 non abs for passenger for sure but driverside depeneds on the 1/2 shaft. sk7 or sk8? i believe it was. how do i tell which 1/2 shaft is which? and what axle do i use with which one.
i have done a considerable amount of searching but found no definate answers
thanks
Old Oct 25, 2007 | 08:39 PM
prettylew's Avatar
Default Re: b16 crx axle bind issues need help (strawberry)
umm right from the FAQ sticky on the top of this page.
http://web.archive.org/web/200...s.htm
Old Oct 25, 2007 | 08:43 PM
alscrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strawberry &raquo;</TD></TR><TR><TD CLASS="quote">i'm having problems with axle bind i was told i need 90-93 non abs for passenger for sure but driverside depeneds on the 1/2 shaft. sk7 or sk8? i believe it was. how do i tell which 1/2 shaft is which? and what axle do i use with which one.
thanks</TD></TR></TABLE>
First off where did you buy you motor from and did it come with the tranny?
What ecu did it come with?
Did your motor come with the halfshaft or did you buy it seperate???
I ask all this so i can tell if its an SIR or XSI
A XSI halfshaft simply uses a 90-93 integra axles non-abs for both sides. Axles have males on both ends of each axle.
SIR halfshafts need "RAXLES" Its a combination of the 88-89 integra axles and 90-93 axles.
Also make sure when installing the axles the big gold dust ring on the back of the hub is OFF. Otherwise the axle wont seat all the way in.
Also engine placement plays a factor with axle bind. Who makes your mounts??
Modified by alscrx at 12:55 AM 10/26/2007
Old Oct 26, 2007 | 09:18 AM
strawberry's Avatar
i got the motor from another car so i'm not to sure.
its a ys1 tranny
the ecu in the car is a pr3
the car it was in didn't have any problems drove it for two days before i pulled it. but the passenger axle was shot and so i used the 90 93 ls non abs axle.
the driverside seems to be fine has play where as the passenger side doesn't.
dust rings are gone.
i'm using hasport with the black inserts.
Old Oct 26, 2007 | 10:48 AM
alscrx's Avatar
Default Re: (strawberry)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strawberry &raquo;</TD></TR><TR><TD CLASS="quote">i got the motor from another car so i'm not to sure.
its a ys1 tranny
i'm using hasport with the black inserts.</TD></TR></TABLE>
OK so its prob a sir b16. If you have hasport mounts there should def be no axle bind. You should get either RAXLES or HASPORT axles. That drivers axles are a combo of the 2 integra's and can't be bought in an auto store!
So what side is binding?
You said you replaced the pass axle with 90-93. That should have worked out good, So your concerned about driver side replacement?
Old Oct 26, 2007 | 02:41 PM
strawberry's Avatar
correct driverside.
thanks for all the help.
if i get a da half shaft i can then use da axles on both sides correct?
Old Oct 26, 2007 | 04:07 PM
civicjdmb16a's Avatar
i had the same setup and same problem. I used a 89 integra axle and it fixed all
Old Oct 29, 2007 | 07:38 AM
alscrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strawberry &raquo;</TD></TR><TR><TD CLASS="quote">correct driverside.
if i get a da half shaft i can then use da axles on both sides correct?</TD></TR></TABLE>
Yup a DA half shaft can use 90-93 teg axles on both sides
Old Oct 29, 2007 | 07:43 AM
ludesrv's Avatar
90-93 half shaft will be a female.
94+ half shaft will be a male.
Get the driveshaft accordingly.
It really is THAT simple.
NOTE: I've noticed that the 90-93 halfshafts are design in a way that make the removal of the driveshaft easier vs. the 94+. That's personal preference.
border919
Jan 23, 2009 09:07 PM
xMRDR3Wx
27
Jul 8, 2007 06:44 PM
Soon2bH2b
Jun 25, 2007 05:23 AM
jacoop86
Aug 11, 2006 04:07 PM
superbeastcrx
12
Nov 22, 2004 03:37 PM
