Dies when i get gas?
hopefully you guys can help
when i put gas in and start up the car..the car will start then die or sometimes not start at all
i have to try to start it more than once everytime i put even 1 gallon of gas in..this starting happening about the beginning of this month..what could be the problem?
*LS motor into Civic*
question two..kinda off topic..but will an 00 SI exhaust fit a LS header? are they the same length or if i buy one from a site do i get a civic one or integra one?
thanks!
thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazyhmongboi »</TD></TR><TR><TD CLASS="quote">hopefully you guys can help
thanks!
Try to do a diagnostic troubleshoot. What's cutting out, fuel? electrical power? Honda has some problem electrical paths, like the main relay or the ignition switch. Post the findings of your tests.
thanks!
</TD></TR></TABLE>Try to do a diagnostic troubleshoot. What's cutting out, fuel? electrical power? Honda has some problem electrical paths, like the main relay or the ignition switch. Post the findings of your tests.
I had this problem with my 92 eg6 not too long ago. I could drive the car for days but after I would get gas it would take forever to start... It turns out that I needed to change my main relay, I'm still not 100% sure why but it definately solved the problem.
LvN
19
Jun 8, 2006 06:58 AM
LvN
Jun 6, 2006 12:21 PM
