Suspension & Brakes Theory, alignment, spring rates....
Best way to level car height..One side is always higher than the other
Old Oct 25, 2007 | 07:44 PM
Halo's Avatar
Default Best way to level car height..One side is always higher than the other
What is the proper measurement points to measure ride height? I have been measuring from the center cap to the top of the fender and it seems one side is always higher or lower than the other..
Thanks in advance
Old Oct 25, 2007 | 08:09 PM
hayabusa160's Avatar
Default Re: Best way to level car height..One side is always higher than the other (Halo)
i never really liked to measure from the fenders because its not really accurate. user error. and sometimes the fenders are not always the same on each side epecially after you rolled the fenders.
measure from the jacking points on the car.
Old Oct 25, 2007 | 08:28 PM
slammed_93_hatch's Avatar
Default Re: Best way to level car height..One side is always higher than the other (hayabusa160)
the car is not level from the factory either
Old Oct 25, 2007 | 11:49 PM
Tyson's Avatar
Default Re: Best way to level car height..One side is always higher than the other (slammed_93_hatch)
it certainly isnt level after years or even decades of driving.
i use top of the fender liner to measure. shrug.
Old Oct 26, 2007 | 05:37 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Measuring from wheel to center to top of wheel-well arch should be the best way if you want the amount of tire-to-fender gap to be even all the way around. Even with differences from rolled fenders, it shouldn't be off by more than 1/8" or so. If you measure from wheel center, that will be a constant measurement no matter what tire size is on there.
I personally just measure from ground to top of fender arch, since all 4 of my tires are the same size.
If you measure from ground to jacking points, that will make the body of the car level with the ground, but the tire gap may or may not be the same front to rear.
Old Oct 26, 2007 | 11:35 AM
Halo's Avatar
Default Re: (PatrickGSR94)
Well I finally found some level ground (harder acomplishment than one would think) I checked all my tire pressure and it's equal. My measurements were all equal 20" from center of wheel to top fender on all 4 corners..yet still the damn left side sits higher aaarrrgh this drives me nutz
Old Oct 26, 2007 | 01:03 PM
Syke Fu's Avatar
Default Re: (Halo)
Blame Honda for improper weight distribution.
Old Oct 26, 2007 | 01:20 PM
doubleshotz's Avatar
Default Re: (Syke Fu)
Time to check for missing bolts, pins, and torn bushings?
Really though, is it that noticable?
Old Oct 26, 2007 | 03:16 PM
Halo's Avatar
Default Re: (doubleshotz)
no but you know
Old Oct 26, 2007 | 03:18 PM
Tyson's Avatar
Default Re: (Halo)
get over it.
Old Oct 27, 2007 | 12:14 PM
Community Builder
umm how could the measurement on all 4 corners be 20" yet the car sit uneven? Only thing I can think of would be bent frame.
Old Oct 27, 2007 | 08:07 PM
Halo's Avatar
Bent frame is not a possibility, I know all the history of the car since new. Do you think corner balancing would be the answer? Maybe the lude has some cooky type of weight distribution
Modified by Halo at 12:06 AM 10/28/2007
Old Oct 28, 2007 | 01:37 AM
Tyson's Avatar
Default Re: (Halo)
proper corner balancing by adjusting coilover spring heights does not acheive equal ride heights. thats NOT the point of corner ballancing, and thats NOT what you would get. you would get very uneven ride heights if you actually did a corner balancing.
seriously. just live with it. everyones car is like this. you need adjustable spring kits like ground controls to have any control over ride heights.
Old Oct 28, 2007 | 01:45 PM
Halo's Avatar
Default Re: (Tyson)
well I just figured out why it the height is off the springs are not seating properly, not sure what the hell is going on
Old Oct 28, 2007 | 02:22 PM
Junkie's Avatar
My left side is a solid finger lower than my right, due to old stock springs...
doingthemost
Feb 19, 2013 08:33 PM
808zrk
Suspension & Brakes
Jan 30, 2012 02:43 AM
bopbop93030
Suspension & Brakes
Mar 29, 2009 08:57 AM
Moejos
Suspension & Brakes
Mar 9, 2009 01:11 PM
Siegfried
May 29, 2007 11:21 AM
