Turning off ABS light
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">Did you pull the ABS codes to determine why the light is illuminated? The Integra FAQ thread has a instruction link.</TD></TR></TABLE>
x2
just fix the problem. ABS is awesome.
x2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eilros »</TD></TR><TR><TD CLASS="quote">My ABS doesn't work on my '94 GSR and I'd like to disable the light. What is the easiest way to do that?
Do you want ABS? If not then simply take out the bulb or take out the fuse... but since the ABS isn't working you wouldn't really need to take out the fuse.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98BabiGs-T »</TD></TR><TR><TD CLASS="quote">
Do you want ABS? If not then simply take out the bulb or take out the fuse... but since the ABS isn't working you wouldn't really need to take out the fuse.</TD></TR></TABLE>
I don't care if I have ABS or not. I just want the indicator light to go away. I could find instructions on the site for removing the bulb. Does anyone have a link?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">Pull cluster.
Remove bulb.
You could be avoiding an easy fix. But that is just my opinion.</TD></TR></TABLE>
Do you have instructions for pulling the cluster? If I can find the ABS codes thread, I'll try fixing it first but if that doesn't work, I'll just remove the bulb. I don't want to put too much money into fixing it.
Remove bulb.
Just pull the screws for the garnish.
http://www.sonsacuraparts.com/...ch=no
And pull the cluster. There are screws around the perimeter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eilros »</TD></TR><TR><TD CLASS="quote">I tried the paper clip jump and nothing happened. My ABS light didn't blink at all, it just stayed illuminated. Any ideas?</TD></TR></TABLE>
What are you talking about...? Are you trying to get the code? I thought you wanted to take the bulb out, no?
I did want to take the bulb out but I thought I'd troubleshoot first. I was trying to get the ABS code using the paperclip jump to see if it's an easy, inexpensive fix.
</TD></TR></TABLE>I did want to take the bulb out but I thought I'd troubleshoot first. I was trying to get the ABS code using the paperclip jump to see if it's an easy, inexpensive fix.
the wire to jump is under the steering colum not the one by the ecu.
there is a procedure to reset it.
if i remeber correctly turn on postion jump it wait for a the light to go out then on plug it in does this like three time
