d16a6 Jackson Racing Supercharger on ZC?
Old Oct 25, 2007 | 07:08 PM
1RMDave's Avatar
Default d16a6 Jackson Racing Supercharger on ZC?
Would would it take to put a jrsc for a d16 on a zc? Could I just cut the flange off the jrsc and weld on the zc flange? Its just so much cheaper/easier to find d series chargers forsale.
Old Oct 25, 2007 | 07:17 PM
STREETWERKZ's Avatar
Default Re: d16a6 Jackson Racing Supercharger on ZC? (1RMDave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1RMDave &raquo;</TD></TR><TR><TD CLASS="quote">Would would it take to put a jrsc for a d16 on a zc? Could I just cut the flange off the jrsc and weld on the zc flange? Its just so much cheaper/easier to find d series chargers forsale.</TD></TR></TABLE>
a SOHC ZC or a DOHC ZC?
if its a SOHC, it'll bolt right up. if its a DOHC, buy an adapter plate from http://www.ZCspeed.com
http://zcspeed.com/adapterpage.htm
Old Oct 25, 2007 | 07:31 PM
SIred91's Avatar
Rainman
Default Re: d16a6 Jackson Racing Supercharger on ZC? (STREETWERKZ)
And there you have it.
Couldn't have said it better myself.
Old Oct 25, 2007 | 07:56 PM
1RMDave's Avatar
dohc, thanks for the link
Old Oct 25, 2007 | 08:00 PM
Default Re: (1RMDave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1RMDave &raquo;</TD></TR><TR><TD CLASS="quote">dohc, thanks for the link</TD></TR></TABLE>
no problem. good luck!
you may want to contact that company directly if you have any questions with the supercharger install using that adapter plate.
Old Oct 26, 2007 | 07:48 AM
jlicrx's Avatar
Default Re: (STREETWERKZ)
you may want to contact that company directly if you have any questions with the supercharger install using that adapter plate. </TD></TR></TABLE>if you plan to buy a used JRSC to use with the ZCspeed adapter plate on a DOHC ZC, make sure you get the JRSC for the D16A6 and not the D16Z6, D16Y8, etc. - the supercharger itself from any of the kits will bolt right up, however, some of the other components like pulleys, alternator brackets, etc. are not the same - JRSC had different accessory kits for each of the models - if you really and truly know what you are doing, you can probably make the others work, but you may need to purchase (or fabricate) different components in order to get everything to match up - getting new components in itself may be a problem as Jackson Racing sold everything from their old supercharger design to Moss Motors Ltd. and it is my understanding that they are no longer selling new supercharger kits for the D-series engine - i don't know if they still have parts for them or not - you would have to check with Moss Motors
Old Oct 26, 2007 | 11:23 AM
Default Re: (jlicrx)
i used a kit from a d16z6 on my d16a6 with no problems at all.
that whole 8atman thing with his install was a fluke because he purchased a broken kit and expected me to fix the problems mid-install. hehehehe
yes, you can still buy parts new from moss motors. its pretty easy too. just enter the part number in their website to see if its still available.
Old Oct 26, 2007 | 01:53 PM
daveb91's Avatar
I do believe without looking the Y8 has the offest manifold that will be a PITA to run on other d series because of the offset to get around MC.
gen2 crx
11
Oct 15, 2009 03:47 PM
s2k10psi
Dec 30, 2006 03:32 PM
luckeydog14
Feb 16, 2006 04:36 PM
Crx-Racer4Life
Jul 30, 2004 03:48 PM
