OBD2 to OBD2 engine swap
just wondering if this will be a complete plug and play if im taking a b series from a 97 integra and putting into an 94 del sol, then putting the motor from the del sol into the 97 integra? since i have both complete wiring harnesses will i be able to pull the main harness of the ecu throught the firewall? i think this should be pretty straight forward. let me know. thanks
Modified by the.hamburglar at 7:18 PM 10/25/2007
what motor are you putting in the integra b16 or d16? i hope not the d16, but as long as you have the harness to both car u shouldnt have any problems unless you putting the d 16 in the teg
its a b18. ok i will word this better.
im swapping an obd1 lsvtec from a 1994 del sol into a obd2 97 integra. and then putting the 97 integra motor into the 94 del sol.
shift link i wont have to worry about, axles i wont have to worry about. in fact, there is nothing else but the wiring. i dont know how this would work.
can i take off the complete harness from the ecu and all and swap them? thanks
Use the engine harness from the integra on the delsol.
You should be able to plug in the engine harness into the in-car subharness.
You may need to add some wires to the in-car subharness on the delsol depending on the model of the delsol.
greg677
Sep 10, 2016 08:54 AM
Cras-Delsol
Dec 15, 2008 11:47 AM
jaydmej1
Mar 22, 2004 09:09 AM
