Suspension & Brakes Theory, alignment, spring rates....
Checking ABS on 1993 Civic EX?
Old Oct 25, 2007 | 01:52 PM
Platinum.Skillz's Avatar
Default Checking ABS on 1993 Civic EX?
How do I tell if I need ABS axles or not?
Also, I've seen places selling "vTEC" and "non-vTEC" axles... Do I need to pay attention to that as well?
Old Oct 25, 2007 | 02:54 PM
Targa250R's Avatar
be professional
Default Re: Checking ABS on 1993 Civic EX? (Platinum.Skillz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Platinum.Skillz &raquo;</TD></TR><TR><TD CLASS="quote">How do I tell if I need ABS axles or not?
Also, I've seen places selling "vTEC" and "non-vTEC" axles... Do I need to pay attention to that as well?</TD></TR></TABLE>
Is it an EX 2-door or an EX 4-door?
If it's a 4-door, it has ABS standard, so you need the ABS-specific axles.
If it's a 2-door, then you don't need ABS-specific axles because ABS wasn't introduced on EX 2-doors until 1994 (and even then, it was optional). However, you can still use an ABS axle on your non-ABS car - the only difference is the addition of the toothed ABS ring for the Hall-effect wheel speed sensor.
As far as VTEC or non-VTEC, it depends on what VTEC is a criterion for selecting (trim level, ABS, etc.). I'd have to see the application to determine why they are using it.
Old Oct 25, 2007 | 02:59 PM
Default Re: Checking ABS on 1993 Civic EX? (Targa250R)
It's an EX 2-Door.
Thanks for the great information by the way.
bob441
Nov 11, 2015 06:50 PM
darkstormcr
Sep 3, 2011 03:14 PM
tso
Nov 25, 2007 11:49 AM
ILOVEGIRLS
Mar 27, 2002 08:36 PM
