Honda S2000 Honda S2000
Anyone used a 4.9 final drive for the track
Old Oct 25, 2007 | 11:20 AM
Smith 12's Avatar
Default Anyone used a 4.9 final drive for the track
I use a 4.77 right now and havnt really heard of anyone using the 4.9 or higher for track use. Has anyone used it or heard of anyone who has. How did you think it worked. Looking for a little more pull out of corners.
Old Oct 25, 2007 | 11:23 AM
papa5murf's Avatar
Default Re: Anyone used a 4.9 final drive for the track (Smith 12)
I believe it's J's Racing that has one that's using a 5.1 gear.
It think it'll all depend on what track you're at though. You don't want to potentially short change yourself on the long straight away.
Old Oct 25, 2007 | 12:06 PM
Smith 12's Avatar
Default Re: Anyone used a 4.9 final drive for the track (papa5murf)
yeah I guess thats more what im looking for. how big of a difference will there be in straight away speed with a 4.9 compared to the 4.7. mid ohio has the longest straight away of tracks i run. enough to where it would hurt your times more than help?
Old Oct 25, 2007 | 12:53 PM
papa5murf's Avatar
Well I'm not sure what kind of speeds you're hitting at the end of the straight before you have to brake.
If you're bouncing off the rev limiter before hitting that brake zone on the straight then you know you've got the wrong gear set.
On an Ap1 with 245/50/16 tires, 5.1gears will give you a top speed of roughly 138.7 mph, with 4.9gears 144.4 mph, with 4.77gears 148.3 mph. These are calculated numbers and do not factor in head/tail wind, down/up hill and so on.
Old Oct 27, 2007 | 06:32 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papa5murf &raquo;</TD></TR><TR><TD CLASS="quote">Well I'm not sure what kind of speeds you're hitting at the end of the straight before you have to brake.
On an Ap1 with 245/50/16 tires, 5.1gears will give you a top speed of roughly 138.7 mph, with 4.9gears 144.4 mph, with 4.77gears 148.3 mph. These are calculated numbers and do not factor in head/tail wind, down/up hill and so on. </TD></TR></TABLE>
nice disclamier...LOL
01PYTypeR#1140
Dec 1, 2012 09:36 PM
FrodeyEJ1
Nov 6, 2012 09:54 AM
bsmith100
27
Aug 16, 2010 03:00 PM
SOHC_MShue
38
Oct 3, 2003 12:17 AM
Ross
82
Mar 21, 2002 05:21 PM
