Alcohol mixed with gasoline.
Old Oct 25, 2007 | 09:46 AM
ProjectEJ2's Avatar
Default Alcohol mixed with gasoline.
Hey, I was told that if you pour a few spoons for distilled alcohol to the engine, it gives you more power, is that true? also that if you use nitromethan mixed with gasoline increases your power as well, is any of this true?
Old Oct 25, 2007 | 10:04 AM
Crazydave's Avatar
Default Re: Alcohol mixed with gasoline. (ProjectEJ2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectEJ2 &raquo;</TD></TR><TR><TD CLASS="quote">Hey, I was told that if you pour a few spoons for distilled alcohol to the engine, it gives you more power, is that true? also that if you use nitromethan mixed with gasoline increases your power as well, is any of this true?</TD></TR></TABLE>
I wouldn't go messing with nitromethane.
Ethanol is mixed with gasoline currently. Look at your local pump, and it will tell you if ethanol is being used.
I have a friend how mixes ethanal with gasoline to produce a higher octane fuel.... I don't what proportions he uses though
But as far as dumping some distilled alcohol or nitromethane... I woudn't mess with it, especially not nitromethane.
Besides.. with a stock computer controlled motor, I don't see any advantages to messing with fuel... only disadvantages.
on a carburated car, with internal modifications, yes you may see changes.
Old Oct 25, 2007 | 01:33 PM
King V's Avatar
Default Re: Alcohol mixed with gasoline. (Crazydave)
I read an article in Hot Rod Magazine that said unless you run all alcohol, the alky they add to gasoline is more of a filler than anything. Usually "cheaper" gas stations do that.
Old Oct 25, 2007 | 01:46 PM
all-mtr-teg's Avatar
Default Re: Alcohol mixed with gasoline. (King V)
also used as an antifreeze/water remover, most gas stations will ad more alcohol during the winter time.
Old Oct 25, 2007 | 02:50 PM
mmuller's Avatar
Mad Scientist
Default Re: Alcohol mixed with gasoline. (all-mtr-teg)
RC car fuel
Old Oct 26, 2007 | 04:35 AM
King V's Avatar
Default Re: Alcohol mixed with gasoline. (mmuller)
Yeah, some 40%. Make sure you shim the head and put in a cooler glow plug. LOL. That would be total destruction of a normal engine. Would look sweet, though, when it let go.
Old Oct 26, 2007 | 11:24 AM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King V &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, some 40%. Make sure you shim the head and put in a cooler glow plug. LOL. That would be total destruction of a normal engine. Would look sweet, though, when it let go.</TD></TR></TABLE>
no it would not
i have run e85 on the motor + nitro/water/meth on injection and it actually loves it
Old Oct 26, 2007 | 03:32 PM
D16Z6TURBO's Avatar
higher octane does not make power it only allows for maore aggresive timing. Then you can make more power with tuning
DC4R27
Apr 29, 2007 12:08 PM
neverhadahonda
Oct 11, 2006 10:05 AM
Rubixcu7
Mar 5, 2006 07:19 PM
RsxType-Stitch
16
Sep 7, 2005 07:52 PM
Mugen_DC2R
Apr 20, 2004 03:58 AM
