So code p0300 with p0301-p0304
02 s2000 48,000 miles with four related missfire codes.
my systom where: random misfire at high rpms and load. vtec
code p0301-p0304 have a very long diagnosis procedure. damit
but code p0300 is the primary code. takes control. after going through its diagnosis procedure. the repair info said to adjust valves
turned out to be car had never had a valve adjustment.
Adjusted valves problem fixed
anyone else had this problem? with this end result?
Modified by fridaytech at 10:51 AM 10/25/2007
