fuel filter
Old Oct 25, 2007 | 08:16 AM
SIC-CIVIC's Avatar
Default fuel filter
Will changing it help my MPG ?
Old Oct 25, 2007 | 08:20 AM
monicle's Avatar
Default Re: fuel filter (SIC-CIVIC)
no
Old Oct 25, 2007 | 08:57 AM
rivaladore's Avatar
are you getting bad gas mileage?
how about correct PSI in your tires, clean your air filter, tune-up, 02 sensor bad? any cels?, higher octane gas. Run some fuel injector cleaner in your gas tank.
Old Oct 25, 2007 | 10:43 AM
SIC-CIVIC's Avatar
Default Re: fuel filter (rivaladore)
Not getting bad milage, but not as good as my old civic I had a couple years ago (same year and motor/trans) correct psi, new AEM intake, so filter is clean, tune-up/02 sensor?? just bought car not sure when it was done last. no cel's, Did use injector cleaner.
Old Oct 25, 2007 | 11:15 AM
23-10's Avatar
You might aswell change it if you dont know when it was done last.
Old Oct 25, 2007 | 11:19 AM
MeanGreenMachine's Avatar
Default Re: fuel filter (23-10)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 23-10 &raquo;</TD></TR><TR><TD CLASS="quote">You might aswell change it if you dont know when it was done last.</TD></TR></TABLE>
ke98248's Avatar
check spark plugs for correct gap and see if they are worn out.. Might need a new dizzy/spark plug wire set
Old Oct 25, 2007 | 11:55 AM
aries331's Avatar
If over 50k miles, definately change it, it makes a big difference. I always do on my family's cars and when you take the old one out you'll notice how dark and dirty the gas that comes out of it looks. Fuel injector cleaners don't work, that;s just a waste of money unless you have the whole system cleaned by a qualified technician.
Old Oct 25, 2007 | 12:00 PM
fmrprojects's Avatar
Default Re: fuel filter (aries331)
short ram intakes give you bad gas milage too. i changed from short ram to cold air and got 45 miles to the tank. both were aem with k&n filter, same driving conditions too
Old Oct 25, 2007 | 12:05 PM
crazyguy's Avatar
new fuel filter will make your car run smoother as fuel flows better
i changed mine a few months ago cause i think the old one i had one the was over 10 years old
Old Oct 25, 2007 | 07:24 PM
SIC-CIVIC's Avatar
Default Re: fuel filter (crazyguy)
Need help guys, changed the fuel filter, but the copper washer for the bottom line (from tank) did not line up right so it distorted the washer and leaked, took it off, went to parts store got another washer did it again, same thing. How the hell are you supposed to get that bottom washer to line up?
Old Oct 25, 2007 | 07:40 PM
b16a3delsol's Avatar
while on the subject of fuel filters. When I got my car i noticed that someone had removed the factory fuel filter setup. base and all. they replaced it with just some inline filter. could this make the car seem like it is just cutting out sometimes like it doesnt want to take fuel efficiently. thanks sorry for threadjacking.
Old Oct 25, 2007 | 08:43 PM
SIC-CIVIC's Avatar
Default Re: fuel filter (monicle)
ok, apperantly it comes w/ a extra small copper washer for diff. applications, (CRV maybe). I took the washer out and put the original filter back on, tightened everything and no leaks. The weird thing is when I took it off there was a washer on that bottom line, it was all mashed up and blocking like 1/2 the flow through the filter, but was not leaking. Oh well, hopfully thats solves my lower then avg. MPG.
Modified by SIC-CIVIC at 11:46 PM 10/25/2007
thunderboy
May 27, 2008 10:09 PM
high23lhatch
Nov 20, 2006 04:29 PM
Oreo-TeCk
Sep 28, 2006 09:30 AM
BLUE EH3
Jun 18, 2004 04:59 PM
Orig
Jun 2, 2002 09:27 AM
