1995 Acura Integra Sometimes Starts.
Old Oct 25, 2007 | 07:52 AM
Phil McKrevice's Avatar
Default 1995 Acura Integra Sometimes Starts.
n00b here, please give me some insight so I can fix my car....
The issue I am having is when I go to start the car sometimes it does not start. All it does is click, it doesn't even turn over. When I try again I usually release the clutch and push it harder and most of the time it will start right up. There have been a few times that it takes 2-4 times to finally start. Someone had told me that in my type of car that there is a sensor for it to start.
Someone said neutral safety switch, but manual cars don't have them unless I am missing something. I also heard about a clutch switch?
Old Oct 25, 2007 | 09:04 AM
thewrai6th's Avatar
Default Re: 1995 Acura Integra Sometimes Starts. (Phil McKrevice)
It could be the starter. Depends on where the click is coming from. There is a clutch switch, but you wouldn't even hear a click if it was not engaged.
You can take a jumper cable and tap the starter positive to check if it's working. (MAKE SURE THE CAR IS NOT IN GEAR)
Also check the grounds on the starter/transmission.
http://www.hondahookup.com there is you shop manual.
Old Oct 25, 2007 | 09:49 AM
thanks man, you saved me a bunch of messing around. No need to check that switch if that is not the culprit. I am going to clean the terminal posts tonight, and the negative ground strap on the engine. I'll check the starter out this weekend.
Old Oct 25, 2007 | 11:11 AM
b20sedan's Avatar
B20 Bhai M.B.B.S
Default Re: (Phil McKrevice)
Bump, I have the same problem!
Old Oct 25, 2007 | 11:23 AM
2.0L Beater's Avatar
I Got the same problem to...sometimes it so bad i rather just push start then f#ck with it haha..i think its the starter..my pops was tellin me to take to get rebuilt...its cheaper
Old Oct 31, 2007 | 08:30 PM
Hey guys it was the starter. The solenoids were going out from what my mechanic friend told me. Starts up every time no problem now.
Auby
Mar 3, 2009 01:50 PM
fullboostin
Jan 4, 2008 03:49 PM
03K24A4EX
May 26, 2006 04:47 AM
jerBEAR
Oct 31, 2005 10:34 AM
DrewQ1
May 4, 2004 09:14 PM
