Suspension & Brakes Theory, alignment, spring rates....
My Suspension Setup... Opinions?
Old Oct 25, 2007 | 06:30 AM
krkline2gdsm's Avatar
Default My Suspension Setup... Opinions?
Now I am just getting into suspension setups and this is what I created so far.
Omni rear upper and lower control arms
Omni front upper control arms
ES bushings in stock front lower control arms w/ Moog ball joints
ES bushings in trailing arms
Omni full coil over setup (not sure if I should get Sport or Street)
Megan racing rear lower bar
ES sway bar bushings for the front
Stock sway bar diameter
No sway bar in the back
What do you guys think? The car is a daily driver and does see some street pulls a:
Old Oct 25, 2007 | 09:35 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
It helps to tell us what car you have.
I would not get the ES control arm or trailing arm bushings, and take that money and put it towards an ITR rear swaybar with either ASR or Beaks subframe reinforcement (ASR only if it's going on a 96-00 Civic).
Polyurethane control arm bushings are known to crap out after only a year or two, even with regular greasing. If you don't grease them regularly, they'll be shot even sooner.
At the very least, don't put polyurethane in your trailing arm bushings. Those will bind up and not allow the trailing arm to move in the range of motion it was designed for.
Old Oct 25, 2007 | 11:49 AM
Its in a 97 Civic DX. So your saying I should leave the rear trailing arm bushings alone. What should I do about the front lower control arms? Get new rubber bushings?
Does the rest of the setup look fine? Does that rear sway bar setup really worth it?
here is what I found:
http://cgi.ebay.com/ebaymotors...wItem
This the kit your talking about?
Old Oct 25, 2007 | 11:55 AM
I found the ASR kit:
SO your saying just leave the trailing arms alone and front control arms alone and go with this? I atleast wanna replace the ball joints. Its a pet peeve of mine.
Old Oct 25, 2007 | 12:02 PM
bmoua's Avatar
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">It helps to tell us what car you have.
At the very least, don't put polyurethane in your trailing arm bushings. Those will bind up and not allow the trailing arm to move in the range of motion it was designed for.</TD></TR></TABLE>
i'd also like to add, why not run PIC's Apex they run for as much as the omni's do.
Old Oct 26, 2007 | 05:25 AM
Community Builder
Default Re: (krkline2gdsm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krkline2gdsm &raquo;</TD></TR><TR><TD CLASS="quote">Its in a 97 Civic DX. So your saying I should leave the rear trailing arm bushings alone. What should I do about the front lower control arms? Get new rubber bushings?
This the kit your talking about?</TD></TR></TABLE>
Yep that's the one. Yes the sway bar will make a HUGE difference in the way your car handles. It will be immediately noticeable.
*EDIT ummm you better check to see if that includes the swaybar or not. One pic shows it and another one doesn't, so best to contact the seller to find out.
If your control arm bushings are worn, it would be best to replace them with OEM. If they're not that bad then don't even touch them for now.
LogicMotorsports.com
418
Oct 9, 2013 12:37 PM
OmarR
Suspension & Brakes
Aug 25, 2013 05:30 PM
CD5B2
Apr 2, 2013 10:45 AM
pliskin679
Suspension & Brakes
Apr 30, 2007 01:10 PM
00siandrew
Sep 6, 2006 08:37 PM
