rough idle when a/c on
Old Oct 25, 2007 | 05:05 AM
92honda accord's Avatar
Default rough idle when a/c on
92 accord has a rough idle when a/c is on . any clues to that problem. idles fine when a/c off . i know turn the a/c off duh
Old Oct 25, 2007 | 01:25 PM
SOHCMAN's Avatar
Default Re: rough idle when a/c on (92honda accord)
Its likely your Idle Control Valve located on your intake plenum is either dirty or bad. Otherwise your ECU would sense the load increase and increase the air moving through the valve to raise the idle a bit.
Also check your base idle speed (with the ICV unplugged) Do you have a manual? tells you how in plain english...
sohc
Jimmy21
Aug 25, 2012 01:37 AM
23nesnes
Sep 22, 2009 10:21 AM
dannylDAsport
Mar 28, 2004 11:38 PM
mrpickyman
Nov 2, 2002 05:22 PM
